VP-UML User's Guide
Visual Paradigm for UML User's Guide
Last Modified: Aug 20, 2010
Share |
Download single PDF
File Size:  50 MB
Table of Contents
Part I. Getting started
Last Modified: Aug 16, 2010
1. Introduction to Visual Paradigm for UML
Sections
1.1. About Visual Paradigm for UML
1.2. Editions
1.3. Features
1.4. Licensing
1.5. Software Maintenance
1.6. System Requirements
2. Installing Visual Paradigm for UML
Sections
2.1. Installing Visual Paradigm for UML on Windows 2000/NT/2003/XP/Vista
2.2. Installing Visual Paradigm for UML on Mac OSX
2.3. Installing Visual Paradigm for UML on Linux
2.4. Switching edition
2.5. Uninstalling Visual Paradigm for UML
3. Getting started
Sections
3.1. Starting Visual Paradigm for UML
3.2. Interface Overview
4. User interface
Sections
4.1. Menu bar
4.2. Toolbar
4.3. Dockable User Interface
4.4. Diagram navigator
4.5. Model explorer
4.6. Class repository
4.7. Logical view
4.8. ORM pane
4.9. Property pane
4.10. Diagram overview
4.11. Documentation pane
4.12. Stencil pane
5. Working with Projects
Sections
5.1. Creating Project
5.2. Saving Project
5.3. Organizing diagrams by model explorer
5.4. Project dependency
5.5. Maintaining Backups
6. Key concepts
Sections
6.1. Model element and view
6.2. Master view and auxiliary view
Part II. UML modeling
1. Use Case Modeling
Sections
1.1. Drawing use case diagrams
1.2. Documenting use case details
1.3. Documenting flow of events
1.4. Elaborating use case
1.5. Managing actors with actors grid
1.6. Managing use cases with use cases grid
2. Behavioral Modeling
Sections
2.1. Drawing activity diagrams
2.2. Drawing state machine diagrams
2.3. Drawing timing diagrams
3. Interaction Modeling
Sections
3.1. Drawing sequence diagrams
3.2. Drawing communication diagrams
3.3. Drawing interaction overview diagrams
4. Structure Modeling
Sections
4.1. Drawing class diagrams
4.2. Drawing object diagrams
4.3. Drawing package diagrams
4.4. Drawing composite structure diagrams
5. Deployment Modeling
Sections
5.1. Drawing component diagrams
5.2. Drawing deployment diagrams
6. Test Cases Modeling
Sections
6.1. Modeling and documenting test cases
Part III. Requirements capturing
1. Requirement diagram
Sections
1.1. Creating requirement diagram
1.2. Customizing requirement types
1.3. Requirements grid
2. Textual analysis
Sections
2.1. Recording requirements
2.2. Identifying important terms
2.3. Identifying candidate objects
2.4. Forming diagram from candidate objects
3. CRC card diagram
Sections
3.1. Drawing CRC card diagram
4. User interface designer
Sections
4.1. Creating user interface diagram
4.2. Frame
4.3. Label
4.4. Text field
4.5. Scrollbar
4.6. Combo box
4.7. List
4.8. Table
4.9. Tree
4.10. Web Label
4.11. Web Button Input
4.12. Web Text Input
4.13. Web Combo Box
4.14. Web List
4.15. Web Password Input
4.16. Web File Input
4.17. Annotating the UI design with callout shape
5. Working with glossary
Sections
5.1. Identify glossary term
5.2. Glossary grid
6. ArchiMate diagram
Sections
6.1. Creating ArchiMate diagram in VP-UML
7. Grid diagram
Sections
7.1. Creating grid diagram
7.2. Creating element in grid
7.3. Adding/removing property columns
7.4. Setting the scope of grid content
7.5. Filter and find
Part IV. Database design
Last Modified: Aug 19, 2010
1. Database Modeling
Sections
1.1. Entity Relationship Diagram(ERD)
1.2. Drawing sequence
1.3. Drawing stored procedures
1.4. Drawing triggers
1.5. Controlling primary key values using ID generator
1.6. Customizing ID generator
1.7. Drawing View
2. Synchronization between ERD and Class Diagram
Sections
2.1. Generate class diagram from ERD
2.2. Synchronize from Class Diagram to ERD
2.3. Configure key naming pattern
Part V. Business process modeling
Last Modified: Aug 05, 2010
1. Business Modeling
Sections
1.1. Drawing business process diagrams
1.2. Drawing data flow diagrams
1.3. Drawing event-driven process chain diagrams
1.4. Drawing process map diagram
1.5. Drawing organization charts
1.6. JPDL generation
2. Simulacian
Sections
2.1. What is simulacian?
2.2. Simulacian control panel
2.3. Simulating business process
2.4. Simulacian charts
Part VI. Mind mapping
Last Modified: Jul 05, 2010
1. Mind mapping diagram
Sections
1.1. Drawing mind mapping diagram
1.2. Formatting nodes
1.3. Linking nodes
1.4. Reference to resources
1.5. Relocating a branch
1.6. Layout nodes and diagram
Part VII. Modeling toolset
Last Modified: Aug 17, 2010
1. Organizing works with model
2. Animacian
Sections
2.1. What is animacian?
2.2. Animating business process diagram
2.3. Animating sequence diagram
2.4. Animating activity diagram
2.5. Export animation to Adobe Flash
3. Maintaining project dependency
Sections
3.1. Depending Another Project
3.2. Referencing other projects' model elements
3.3. Mirroring model element
3.4. Viewing dependent diagrams
3.5. Duplicating element from linked project
4. Model Element Nicknaming
Sections
4.1. What is nickname?
4.2. Configure nickname
4.3. Using nickname
4.4. Translation
5. Visual Diff
Sections
5.1. What is visual diff?
5.2. Comparing as-is and to-be business process diagram
5.3. Comparing logical and physical ERD
6. Using design pattern
Sections
6.1. Defining design pattern
6.2. Applying design pattern
6.3. Synchronize design pattern with teamwork server
7. Model transitor
Sections
7.1. Model transitor for shape
7.2. Model transitor for diagram
8. Using Stereotypes
Sections
8.1. Apply Stereotype to Model Element
8.2. Configure stereotypes
8.3. Shortcut of creating stereotyped model element
9. Customizing elements with profile
Sections
9.1. Creating a profile
9.2. Drawing a profile diagram
Part VIII. Diagramming toolset
Last Modified: Aug 09, 2010
1. Creating Diagrams
Sections
1.1. Creating Diagrams
1.2. Resource Centric Interface
1.3. Tagged Values
1.4. Spell Checking
2. Project management properties
Sections
2.1. Using project management properties
2.2. Configuring project management properties loop-up
3. Documenting model elements
Sections
3.1. RTF documentation
3.2. Voice documentation
4. Style and Formatting
Sections
4.1. Applying fill, line and font styles on diagram elements
4.2. Managing and applying styles
4.3. Setting line style
4.4. Setting line jumps options
4.5. Setting connector caption orientation
4.6. Format copier
5. General modeling techniques
Sections
5.1. Automatic Diagram Layout
5.2. Fit Shape Size
5.3. Diagram Element Selection
5.4. Copy and paste
5.5. Alignment guide
5.6. Reverse connector direction
5.7. Visualize model elements on diagram
5.8. Visualize related model elements
5.9. Adding comments
5.10. Pinning connector ends
5.11. Align and distribute diagram elements
5.12. Adjusting caption's position and angle in BPD
6. Advanced Modeling Techniques
Sections
6.1. Sweeper and magnet
6.2. Mouse gestures
6.3. Jumping to shape
6.4. Grouping diagram elements
6.5. Show/hide diagram elements
6.6. Layer
6.7. Making shape non-selectable
6.8. Locking diagram
6.9. Showing model element in multiple diagrams (Context base modeling)
6.10. Using overview diagram
7. Drawing annotations and freehand shapes
Sections
7.1. UML note
7.2. Callout shape
7.3. Freehand shapes
8. Resource Referencing
Sections
8.1. Reference to external resources
8.2. Reference to diagrams and shapes
8.3. Elaborating model element with sub diagram
8.4. Showing sub diagrams and reference indicators
9. Using shape editor
Sections
9.1. Creating Shape in Shape Editor
9.2. Creating Shapes from Stencil Pane
10. Customizing user interface
Sections
10.1. Hiding user interface components
10.2. Adjusting user interface font
Part IX. Code and DB engineering
1. Instant Reverse
Sections
1.1. Reverse engineering of Java sources and classes
1.2. Reverse engineering of C++ header files
1.3. Reverse engineering of .NET dll and exec files
1.4. Reverse engineering of CORBA IDL source file
1.5. Reverse engineering of Ada 9x source files
1.6. Reverse engineering of XML
1.7. Reverse engineering of XML schema
1.8. Reverse engineering of Database through JDBC
1.9. Hibernate mapping file
1.10. Reverse engineering of PHP 5.0 source files
1.11. Reverse engineering of Python
1.12. Reverse engineering of Objective-C
1.13. Java to sequence diagram
2. Instant Generation
Sections
2.1. Instant Generator for Java
2.2. Instant generate for C# source code
2.3. Instant generate for VB.NET source code
2.4. Instant Generator for PHP source code
2.5. Instant Generator for ODL source code
2.6. Instant Generator for ActionScript source code
2.7. Instant Generator for IDL source code
2.8. Instant Generator for C++ source code
2.9. Instant Generator for Delphi source code
2.10. Instant Generator for Perl source code
2.11. Instant Generator for XML schema file
2.12. Instant Generator for Python source code
2.13. Instant Generator for Objective-C source code
2.14. Instant Generator for Objective-C 2.0 source code
2.15. Instant Generator for Ada95
2.16. Instant Generator for Ruby
2.17. Customizing code generation
3. Java Round-Trip
Sections
3.1. Generate or Update Java code from UML classes
3.2. Generate or update UML classes from Java code
4. C++ Round-trip
Sections
4.1. Generate or Update C++ code from UML classes
4.2. Generate or update UML classes from C++ code
5. Generating Database
Sections
5.1. Database Configuration
5.2. Generating SQL for selected entities
5.3. Generating SQL for project
5.4. Generating alter statements
5.5. Export and import database configuration between projects
5.6. Entering and generating default data
6. Reversing Database
Sections
6.1. Reversing database
6.2. Reversing DDL
7. Generating Object-Relational Mapping Code
Sections
7.1. Generating code and database
7.2. Lazy collection setting
7.3. Persistent API
7.4. Using generated code
7.5. Customizing getter and setter body
8. State Machine Diagram Code Generation
Sections
8.1. Modeling guidelines
8.2. Generating state machine code
Part X. Impact analysis
Last Modified: Jul 09, 2010
1. Introduction of Impact Analysis
Sections
1.1. Introduction of impact analysis
2. Analysis Diagram
Sections
2.1. Analyzing a model element
2.2. Updating analyzed result
2.3. Grouping of nodes
2.4. Opening view from node
3. Matrix Diagram
Sections
3.1. Creating a Matrix
3.2. Reading a matrix
Part XI. Report generation
Last Modified: Jul 08, 2010
1. Generating HTML/PDF/Word report
Sections
1.1. Generating report
1.2. Configuring report
2. Customizing report
Sections
2.1. Customizing report
2.2. Export/import report template
2.3. Diagram loop
2.4. Diagram summary
2.5. Diagram paragraph
2.6. Element loop
2.7. Element summary
2.8. Element paragraph
2.9. Custom content
2.10. Diagram Image
2.11. Property value
2.12. Page break
3. Publishing project to Web Site
Sections
3.1. Publish project using project publisher
3.2. Using the published contents
4. Report Writer
Sections
4.1. Installing report writer
4.2. Creating report
4.3. Introduction to report writer user interface
4.4. Constructing report
4.5. Updating report content
4.6. Export and import report
4.7. Customizing Report Writer Template
Part XII. Interoperability and integration
Last Modified: Aug 03, 2010
1. Export and Import XML
Sections
1.1. Exporting XML
1.2. Importing XML
2. Export and Import VP Project
Sections
2.1. Exporting VP project
2.2. Importing VP project
3. Export and Import Microsoft Excel
Sections
3.1. Exporting to Microsoft Excel
3.2. Importing Microsoft Excel file
3.3. Excel modification guidelines
4. Export and Import XMI
Sections
4.1. Exporting XMI
4.2. Importing XMI
5. Importing Visio Drawing
Sections
5.1. Importing Visio Drawing into VP-UML
6. Importing Rational Rose Model
Sections
6.1. Importing Rational Rose Model into VP-UML
7. Importing Rational Software Architect File
Sections
7.1. Importing Rational Software Architect EMX into VP-UML
7.2. Importing Rational Software Architect DNX into VP-UML
8. Importing Erwin Data Modeler Project File
Sections
8.1. Importing ERwin Data Modeler project file into VP-UML
9. Importing Telelogic Rhapsody and System Architect Project File
Sections
9.1. Importing Telelogic Rhapsody project into VP-UML
9.2. Importing Telelogic System Architect into VP-UML
10. Importing NetBeans 6.x UML Diagrams
Sections
10.1. Importing NetBeans 6.x UML diagrams into VP-UML
11. Exporting Diagram to Various Graphic Formats
Sections
11.1. Exporting active diagram as image
11.2. Exporting multiple diagrams as images
11.3. Exporting portion of diagram as image
12. Extend Functionalities with Open API
Sections
12.1. Introduction to plugin support
12.2. Implementing plugin
12.3. Deploying plugin
13. Command Line Operations
Sections
13.1. Exporting diagram image
13.2. Exporting and importing XMI
13.3. Exporting and importing XML
13.4. Generating ORM code and/or database
13.5. Generating report through command line
13.6. Instant generator
13.7. Instant reverse
13.8. Java code synchronization
13.9. Project publisher
13.10. Updating teamwork project from server
13.11. Executing operations with Apache Ant
14. Printing Diagrams
Sections
14.1. Printing diagrams
14.2. Quick print
Part XIII. Team collaboration
1. Team Collaboration with VP Teamwork Server
Sections
1.1. Introduction to team collaboration
1.2. The Teamwork Client with VP Teamwork Server
1.3. Checkout project with VP Teamwork Server
1.4. Commit with VP Teamwork Server
1.5. Update with VP Teamwork Server
1.6. Branching with VP Teamwork Server
1.7. Tagging with VP Teamwork Server
1.8. Revert local modification
1.9. Roll back past revisions changes
1.10. Export revision
2. Team Collaboration with Subversion
Sections
2.1. Introduction to team collaboration with Subversion
2.2. The Teamwork Client with Subversion
2.3. Checkout project
2.4. Commit with Subversion
2.5. Update with Subversion
2.6. Branching with Subversion
2.7. Tagging
2.8. Revert Local Modification
2.9. Roll back Past Revisions Changes
2.10. Export revision
3. Team Collaboration with CVS
Sections
3.1. Working with teamwork client dialog box with CVS
3.2. Importing projects to CVS server
3.3. Checkout project from CVS server
3.4. Committing local modification to CVS server
3.5. Resolving conflicts
3.6. Updating latest revision from CVS server
3.7. Rolling back undesired changes by reverting changes
3.8. Browsing change histories (old revisions) with CVS
3.9. Isolating last long modifications with Branches with CVS
3.10. Marking release or milestone with tags with CVS
4. Team Collaboration with Perforce
Sections
4.1. Working with teamwork client dialog box with Perforce
4.2. Importing projects to Perforce
4.3. Checkout project from Perforce
4.4. Committing local modification to Perforce
4.5. Resolving conflicts
4.6. Updating latest revision from Perforce
4.7. Rolling back undesired changes by reverting changes
4.8. Browsing change histories (old revisions) with Perforce
4.9. Isolating last long modifications with branches
4.10. Marking release or milestone with tags
5. Diagram protection
Sections
5.1. Diagram protection
Part XIV. Appendix
Last Modified: Jul 12, 2010
1. Configure Environment Options
Sections
1.1. General Options
1.2. Diagramming options
1.3. View options
1.4. Instant reverse options
1.5. ORM options
1.6. State code engine options
1.7. Office exchange options
1.8. User path options
1.9. Data type options
1.10. File type options
1.11. Code synchronization options
1.12. C++ Code Synchronization
1.13. Spell checking options
1.14. Keys options
2. Automatic Update
Sections
2.1. Updating VP-UML with VP Suite update
2.2. Automatic update notification
3. Connection Rules
Sections
3.1. Use case diagram connection rules
3.2. Class diagram connection rules
3.3. Sequence diagram connection rules
3.4. Communication diagram connection rules
3.5. State machine diagram connection rules
3.6. Activity diagram connection rules
3.7. Component diagram connection rules
3.8. Deployment diagram connection rules
3.9. Package diagram connection rules
3.10. Object diagram connection rules
3.11. Composite structure diagram connection rules
3.12. Interaction overview diagram connection rules
3.13. Requirement diagram connection rules
3.14. Basic diagram
3.15. Entity relationship diagram connection rules
3.16. ORM diagram connection rules
3.17. Business process diagram connection rules
3.18. Conversation diagram connection rules
3.19. Data flow diagram
3.20. EPC diagram
3.21. Process map diagram
3.22. Organization chart connection rules
3.23. Archimate diagram connection rules
3.24. EJB diagram
3.25. Overview diagram connection rules
3.26. Mind mapping diagram
Still need help?
Technical Support provides online answers to your technical questions and troubleshoots any technical issues related to Visual Paradigm products.
Call Back Support provides one-on-one phone real person conversation support for any technical and sales enquiries about our products. Our support team will call you back as soon as possible.
Our Discussion Forum accepts messages from users all around the world. If you want to share your questions, suggestions or opinions with other users or our staffs, please submit your message to our Discussion Forum
