Technical Support
Sales Support
A stereotype defines how a model element may be extended, and enables the use of platform or domain specific terminology or notation in place of, or in addition to, the ones used for the extended metaclass. In VP-UML, you can apply one or more stereotypes to model elements, and decide whether or not to visualize the stereotype or tagged values in views. To apply stereotype to model element:
| Select a stereotype |
| Stereotype Enum is selected |
| NOTE: | You can also double click on a stereotype to apply it. |
| NOTE: |
While clicking on > applies the selected stereotype to model element, you can click < to remove a stereotype selected in Selected list. If you want to apply ALL available stereotypes to model element, click >>, and likewise, clicking on << removes all the applied stereotypes. |
| Stereotype Enum is applied to a class |
Robustness analysis helps to find out the relationships between actor, boundary, control and entity objects.
| Robustness analysis icons |
To draw a robustness analysis diagram with robust analysis symbols:
| Apply entity stereotype to User class |
| NOTE: | If you want to let a class display as traditional class shape instead of robustness analysis icons, right click on the class and de-select Presentation Options > Display as Robustness Icon from the popup menu. |
You can specify icon for a stereotype (Read the next chapter for details). When a stereotype is applied to a model element, you can let the stereotype icon show above the name of model element, which is the default presentation, or to make the model element show as the icon. To present a shape as stereotype icon, right click on the shape and select Presentation Options > Stereotype Icon from the popup menu.
| Different presentations of a model element with a stereotype that has icon defined |
By default, applied stereotypes are shown within a shape. Yet, it is up to you whether to show or hide them. Furthermore, you can choose not to display the stereotypes, but to display only their tagged values.
To update the visibility of stereotypes, right click on the background of diagram where the shapes exist. Select/De-select Presentation Options > Show Stereotypes from the popup menu.
| A use case with stereotype names shown and hidden |
| Chapter 8. Using Stereotypes | Table of Contents | 2. Configure stereotypes |
Technical Support
Sales Support
