VP-UML User's Guide
Part I. Getting Started
Part II. Visual Modeling
Part III. UML Modeling
Part IV. Business Modeling
Part V. Database and ORM Modeling
Part VI. Stereotypes and Profile Management
Part VII. Team Collaboration
Part VIII. Documentation Publishing and Printing
Part IX. Code Engineering
Part X. Interoperability
Part XI. Impact Analysis
Part XII. General
Table
Table is used to display and edit regular two-dimensional tables of cells.
Creating a table
  1. Select the Table tool from the diagram toolbar.
    Selecting Table from diagram toolbar
  2. Press to set the position of the table. Drag diagonally from the starting point to expand the table.
    Drag diagonally to expand the Table
  3. Release the mouse button to confirm the size of table.
    Table is created
    Table is created
Editing table contents
Basic setup
To insert columns and rows into a table:
  1. Right click on the table and select Open Specification... from the popup menu.
  2. In the UI tab of the UITable Specification dialog box, click either Insert Column to Left or Insert Column to Right to insert the first column.
    Insert a column into table
  3. Enter the column name in Input dialog box and click OK to confirm.
  4. Repeat step 2 and 3 to create all columns.
  5. Click Insert Row Below to insert a row. Note that a row can be inserted only when there is a column exist.
    Insert a row into table
  6. A row is created with empty cell(s). Fill in the cell(s) if necessasry. Cell can be edited by double clicking or by pressing the F2 key.
  7. Repeat step 5 and 6 to create all rows.
  8. Click OK to confirm editing.
    Table with data
    Table with data
Removing a column
To remove a column in a table, open UITable Specification dialog box, open the UI tab, right click on a cell of a column and select Remove Column in the popup menu.
To remove a column in table
Removing a row
To remove a row in a table, open UITable Specification dialog box, open the UI tab, right click on a row and select Remove Row in the popup menu.
To remove a row in table
Reordering rows
To reorder rows, open UITable Specification dialog box, open the UI tab,select the row(s) to reorder, and click on the Move Selected Rows Up or Move Selected Rows Down button.
Moving a row in table upwards
Table properties
The appearance of table can be changed by editing its properties. To configure a table, right click on the table and select Open Specification... from the popup menu. The UI tab is where user can configure a table.
Property Description
Row height
The height of rows in table.
Horizontal scroll bar
Determines when a horizontal scrollbar will appear in a table.
Vertical scroll bar
Determines when a vertical scrollbar will appear in a table.
Auto-resize mode
Determines how the widths of columns will be affected when other columns in the table are being resized.
Off:  Disable auto resizing
Next column: When a column is being resized, all columns on the right and left of margin are updated
Subsequent columns: When a column is being resized, all columns on the right are resized at the same time
Last column : When a column is being resized, width of the right-most column are updated
All columns: When a column is being resized, widths of all columns are changed
Grid color
Determins the color of grid in table.
Show horizontal line
Determines the visibility of horizontal lines in table.
Show vertical line
Determines the visibility of vertical lines in table.
Description of table properties
7. List Table of Contents 9. Tree
Still need help?
Technical Support provides online answers to your technical questions and troubleshoots any technical issues related to Visual Paradigm products.
Call Back Support provides one-on-one phone real person conversation support for any technical and sales enquiries about our products. Our support team will call you back as soon as possible.
Our Discussion Forum accepts messages from users all around the world. If you want to share your questions, suggestions or opinions with other users or our staffs, please submit your message to our Discussion Forum
