Translation
Further to the definition of nickname, you also can make use of the translate function to translate your work into another language. This is particularly useful when you want to add a new nickname for another different language, without entering all names and documentations from the beginning.
To perform a translation:
  1. Right click on the shape you want to perform translation and select Translate... from the pop-up menu.
    Perform translation on a shape
    NOTE: Make sure you are working under a nickname in order to see the Translate menu.
  2. In the Translate dialog box, the left hand side displays the name and documentation of the chosen shape in the language set for original nickname, which is English by default, while the right hand side displays name and documentation in the language of the active nickname.
    Translation outcome
    Translation outcome
  3. Review and make necessary correction to the translated outcome. You can change to translate to another language by selecting a different language from the drop down menu at the bottom right corner of dialog box, and then click the Translate button. Click OK button to proceed with translation.
    A translated business task
3. Using nickname Table of Contents Chapter 5. Visual Diff
Product
Try this feature with
Visual Paradigm for UML
Technical Support
Sales Support
Discussion Forum
