Using nickname
Once you have defined a nickname, you can start updating your model by entering the new names and documentations of model elements.
Start updating elements' nickname
  1. Select Modeling > Nicknames and then select a nickname to work with from the toolbar.
    Select a nickname to work with
  2. Start renaming model elements and updating their documentation. The changes you make will only be applied to the selected nickname.
    Update the name and documentation of elements under a nickname
Switching between nicknames
The names and documentations of model elements are language specific. This means that, the change you make applies only to a specific nickname. Once you have switched to another nickname, the names and documentations of model elements will be updated to show the definition under the new nickname.
To switch between nicknames, select Modeling > Nicknames and then select a nickname to switch to from the toolbar.
Switch nickname
Switch nickname
2. Configure nickname Table of Contents 4. Export and import word document of nickname
Product
Try this feature with
Visual Paradigm for UML
Technical Support
Sales Support
Discussion Forum
