Technical Support
Sales Support
By animating a business process diagram with Animacian, you can see the flow of tasks within a process, from the beginning until the end. This does not only help to understand a process, but also trace the bottleneck and look for improvements.
| Clicking Play in Business Process Diagram Animacian dialog box |
| NOTE: | Animacian can also be started by using any of the ways below:
The Business Process Diagram Animacian dialog box will pop out after clicking Animacian.... This dialog box is where you can select an execution path to play an animation.
| Description of Business Process Diagram Animacian dialog box |
| Advanced Options dialog box |
| The description of Advanced Options dialog box |
The Paths list displays all possible animation paths of your diagram. Each path represents a possible way to go through the diagram. By default, paths are named as Path1, Path2, and so forth. It is recommended to name to the path(s) for better clarification.
| Naming the paths |
In Business Process Diagram Animacian dialog box, all paths are listed in Paths list by default. However, you can manage the flow of animation with your own choice. To create a manual path:
| Selecting Manual in Paths |
You should choose an outgoing flow when there is a gateway in the flow. Different decisions will lead to different forks and make a different outcome for the flow of animation. Make either decision to view the outcome.
| Making a decision for the flow of path |
| Description of Animacian bar |
| Reviewing the animation |
| 1. What is animacian? | Table of Contents | 3. Animating sequence diagram |
Technical Support
Sales Support
