Technical Support
Sales Support
You can use different diagrams for modeling different phases of development, such as a diagram for modeling the current system, and another diagram for modeling to system to be implemented. In order to trace the evolution of model elements across diagrams, you can make use of model transitor. Model transitor enables you to establish transit relationship between shapes. With the transition relationship, you can trace between shapes across diagrams.
| Manage transition |
| Select shapes to transit to |
Once a transition is added between two shapes, you can navigate between them. There are two methods to navigate to a transited shape. The first way is to go through the transitor popup menu of a shape. Right click on a shape and select Related Elements > Transit From/To from the popup menu, then the shape to navigate to.
Alternatively, make use of resource centric interface by following the steps below:
| Navigate to a transited shape through the resource centric interface |
To remove a transition between shapes:
| De-select shapes to withdraw from transition |
| Chapter 7. Model transitor | Table of Contents | 2. Model transitor for diagram |
Technical Support
Sales Support
