Technical Support
Sales Support
Sometimes, just by watching the simulacian outcome is not enough in finding out the bottleneck, especially when the diagram is large, and have many, many bottlenecks. In such cases, you can produce charts for simulacian outcome, which helps quantify resource consumption and queuing time for each flow object.
To read the charts, click Simulacian Charts in simulacian control panel.
| Open simulacian charts window |
The completion chart primarily shows the status of inputs completion against time.
| An overview of completion chart |
| Description of completion chart |
The resource usage chart shows the percentage of resource consumption throughout simulation. If a resource has its peak reaching 100%, it means that the allocation of that resource is in optimum state. If the peak is below 100%, it means that some of the resources are not used throughout the simulation, which usually signifies that they are wasted, and you should consider to adjust the amount of available resource to optimize the resource consumption.
| An overview of resource usage chart |
| Description of resource usage chart |
The queue time chart shows the time the flow objects spent on waiting, which corresponds to the time an inverted triangle appear during simulacian. You may study whether the queue time of certain flow object is reasonable or not, and think of the improvement.
| An overview of queue time chart |
| Description of queue time chart |
The cost per flow object chart shows the cost each flow object consumed throughout simulation.
| An overview of cost per flow object chart |
The cost per input chart shows the cost each input consumed throughout simulation.
| An overview of cost per input chart |
| Description of cost per flow object chart |
The time cost chart shows the cost consumed against time spent throughout simulation.
| An overview of time cost chart |
| 3. Simulating business process | Table of Contents | Chapter 11. Brainstorm |
Technical Support
Sales Support
