Reversing ORM POJO classes
You can generate ORM classes which has POJO be the persistent API. On the contrary, those generated POJO classes can be reversed back to class model. This is particularly useful when you want to produce a class diagram from legacy ORM classes (code).
To reverse engineer class model from ORM POJO classes:
  1. Select Tools > Hibernate > Reverse Java Classes... from the main menu.
  2. In the Reverse Java Classes dialog box, click Add to add the classpaths where the ORM classes exist.
    Add classpath
    Add classpath
  3. From the Available Classes pane, select the classes you want to reverse and click >.
    Add classes to reverse
  4. Click OK. You can find the reversed classes in the Model Explorer.
    ORM classes reversed
Chapter 7. Reverse ORM POJO Classes Table of Contents Chapter 8. Generating Object-Relational Mapping Code
Product
Try this feature with
Visual Paradigm for UML
Technical Support
Sales Support
Discussion Forum
