Start Event (Receive)
To represent the initiation of a BPEL process, you need a start event, which correspond to, in BPEL a receive element with attribute createInstance set to yes. You can specify the partnerLink, portType and operation to be invoked by the start event.
NOTE: An alternative way to start a process is to start by a receive task. Create a receive task, open its specification and check Instantiate in its General tab.
Editing BPEL properties
To edit BPEL properties for a start event, right click on the start event and select Open BPEL Specification... from the popup menu. In the specification dialog box you can specify partner link, operation and variable.
Open BPEL specification
3. Pool (process) Table of Contents 5. Task
Product
Try this feature with
Visual Paradigm for UML
Technical Support
Sales Support
Discussion Forum
