Technical Support
Sales Support
A business process is mainly formed by activities that need to be performed to complete the process. There are two kinds of activities - task and sub-process. A task is an atomic activity which represents work that cannot be broken down. On the contrary, sub-process represents work that can be broken down to a finer level of detail.
| Task and sub-process |
You can assign markers to task. There are three markers: Loop, Multi-Instance, Compensation. A task can have one or two of these markers. Assignment of markers is done through the specification dialog box of task.
| Different markers of task |
| NOTE: | You can click on the ... button next to Loop type to set the loop condition, counter and the maximum number of iteration. |
| NOTE: | You can click on the ... button next to Loop type to set the ordering of loop, either parallel or sequential. |
There are several types of task for you to separate the behavior of different tasks. You can set a type by right clicking on a task and selecting Type, then the type from the popup menu.
| Types of tasks |
You can assign markers to sub-process. There are four markers: Loop, Multi-Instance, Ad-hoc and Compensation. A sub-process can have up to three markers, excluding the marker for collapsed: A loop/multi-instance marker, an Ad-hoc marker, and a Compensation marker. Assignment of markers is done through the specification dialog box of sub-process.
| Different markers of sub-process |
There are several types of sub-process for you to separate the behavior of different sub-processes. You can set a type by right clicking on a sub-process and selecting Type, then the type from the popup menu.
| Types of tasks |
A sub-process can be opened up to model the detail in a lower level. To open up a sub-process, click on the plus marker in sub-process and select New Business Process Diagram. This will create a new business process diagram that belongs to the sub-process.
| To break down a sub-process |
| NOTE: | Once a sub-process diagram is created, its detail will be shown as the sub-process shape as a thumbnail of the diagram. To hide the thumbnail, click on the minus marker at the bottom of sub-process to turn it off. |
In the sub-process diagram, you can re-use pools, lanes and flow objects that appear in the parent diagram. To do this, right click on the sub-process diagram and select Add Pools/Lanes/Sub-Processes/Gateways from Parent Diagram... from the popup menu, and choose the element to reuse. Elements being re-used will have dog ear appear at their corners.
| A sub-process diagram with a lane reused from parent diagram |
You can jump from a re-used element back to the parent diagram through the resource-centric interface.
| Jump to parent diagram |
An activity within a process represents work need to be done. Each activity can be formed by a number of steps. For example, a task Process Application involves 2 steps - validate application, confirm application. To document the steps of an activity, you can make use of the procedure editor.
| Procedure of a task |
| An overview of procedure editor |
| Description of procedure editor |
The procedure editor is opened in business process diagram by default. To hide it, right click on the background of business process diagram and deselect Show Procedure Editor from the popup menu. You can select the same menu to show it when hidden.
| NOTE: | Alternatively, you can close the editor by clicking on the cross button at the top right corner of editor panel. |
| 2. Pool and lane | Table of Contents | 4. Event |
Technical Support
Sales Support
