Event
An event in a business process refers to something that happens and affects the flow of process. There are three types of events: Start, intermediate and end.
Start, intermediate and end events with different kinds of triggers and results
Start event
A start event indicates the place where and possibly why a process start. Since start event is used for initiating a process, it does not have any incoming sequence flow.
You can define a trigger for start event, to show the condition(s) that will cause a process to initiate.
Trigger name
Representation Description
None
The none start event does not have a defined trigger.
Message
This trigger starts the process by receiving a message from a participant.
Timer
This trigger starts the process in a specific time-date or a specific cycle (e.g. every Friday).
Error
This trigger starts an in-line event sub-process when an error occurs. Note that this trigger can only be used with an event-sub-process.
Escalation
This trigger starts or not to start an in-line event sub-process when the constraint specified is not satisfied. Note that this trigger can only be used with an event-sub-process.
Compensation
This trigger starts an in-line event sub-process when an compensation occurs, which require undoing some steps. Note that this trigger can only be used with an event-sub-process.
Conditional
This trigger starts the process when a specific condition become true.
Signal
This trigger starts the process when a signal broadcasted from another process has arrived. Note that signal is different from message, which has a specific target for message.
Multiple
This means that there are multiple triggers of the process. Any one of them can cause the process to start.
Parallel Multiple
This means that there are multiple triggers of the process. All of the triggers must be triggered in order to start the process.
Link
This trigger provide a mean to connect the end result of one process to the start of another.
Different types of start event trigger
Defining a trigger
To define a trigger on an event, right click on the event and select Trigger, then the type of trigger from the popup menu.
To define a start event trigger
If you want to edit the properties of the trigger, such as the condition of a conditional trigger, right click on the event and select Open Specification... from the popup menu. Then, click on the ... button next to the drop down menu of Trigger to edit its properties in the popup dialog box.
Interrupting or Non-interrupting event sub-process
Start event can be attached to the border of an event sub-process, to initiate the sub-process inline. You can define this kind of trigger as either interrupting or non-interrupting, which means to interrupt its containing process or not to interrupt its containing process respectively. To set a trigger to be Interrupting or Non-Interrupting, right click on the event and select/de-select Triggers > Interrupting from the popup menu.
Interrupting (left) and Non-Interrupting (right) events
NOTE: Only triggers that can be attached to event sub-process can set as interrupting/non-interrupting. The supported trigger types include: Message, Timer, Escalation, Error, Cancel, Compensation, Conditional, Signal, Multiple, and Parallel Multiple.
Intermediate event
An intermediate event indicates where something happens in between the start and end event of a process. You can use an intermediate event to show where messages are received or sent, show the necessary delay, perform exception handling and show the need of compensation. You can place an intermediate even in two places: Attaching the boundary of task/sub-process, Normal flow (i.e. connected from a flow without attaching to an activity).
Trigger name
None
The none intermediate event does not have a defined trigger. It is used to indicate change of state in the process. You can only use a none intermediate event in a normal flow.
Message
This trigger represents either a send or receive of message
Timer
This trigger acts as a delay mechanism on a specific date-time or cycle (e.g. every Friday). You can only use a timer intermediate event in a normal flow.
Error
This trigger reacts to a named error, or to any error if no name is specified.
Escalation
The trigger indicates where an escalation is raised. You can only use an escalation intermediate event in a normal flow.
Cancel
This trigger will be fired when a cancel end event is reached within the transaction sub-process. It also shall be triggered if a Transaction Protocol "Cancel" message has been received while the Transaction is being performed.
Compensation
The trigger indicates the need of compensation.
Conditional
The event will be triggered when the condition specified become true.
Link
This trigger is used for linking two sections of a process. You can use it to mode a looping of flow or to avoid having long sequence flow connectors appear on diagram. You can only use a link intermediate event in a normal flow.
Signal
This trigger indicates the sending or receiving of signals, which is for general communication within and across process levels, across pools, and between business process diagrams.
Multiple
This means that there are multiple triggers defined. Any one of them can cause the event to be triggered.
Parallel Multiple
This means that there are multiple triggers defined. All of the triggers must be triggered in order to trigger the multiple event.
Defining a trigger
To define an intermediate event trigger
Throw and catch
You can set an event to be catch or throw. Catch means to react to a trigger, while throw means to create a trigger. To set, right click on an event and select Trigger, then either Catching or Throwing from the popup menu.
A catch event (left) and a throw event (right)
NOTE: The trigger types that can set as throw/catch include: Message, Escalation, Compensation, Link, Signal, and Multiple.
Intermediate event can be attached to the border of an activity. You can set an event to interrupt or not to interrupt the activity to which it is attached. To set a trigger to be Interrupting or Non-Interrupting, right click on the event and select/de-select Triggers > Interrupting from the popup menu.
NOTE: Only triggers that can be attached to event sub-process can set as interrupting/non-interrupting. The supported trigger types include: Message, Timer, Escalation, Conditional, Signal, Multiple, and Parallel Multiple.
End event
As an opposite of start event, end event indicates where a process will end. Since end event is used for terminating a process, it does not have any outgoing sequence flow.
You can define a result for end event, to show what will happen when reaching the end.
Trigger name
None
The none end event does not have a defined result.
Message
This result ends the process by sending a message to a participant.
Error
This result indicates the generation of a named error when the process ends.
Escalation
This result indicates the trigger of escalation when the process ends.
Cancel
This result indicates that the transaction should be cancelled.
Compensation
This result indicates the need of compensation, which require undoing some steps.
Signal
This result indicates that a signal will be broadcasted when the process ends. Note that signal is different from message, which has a specific target for message.
Terminal
This result indicates that all activities in the process should be immediately ended.
Multiple
This result indicates that there are multiple consequences of ending the process.
Link
This result provide a mean to connect the end result of one process to the start of another.
Different types of end event result
Defining a result
To define a result on an event, right click on the event and select Result, then the type of result from the popup menu.
To define an end event result
If you want to edit the properties of the result, such as the message produced by a message result, right click on the event and select Open Specification... from the popup menu. Then, click on the ... button next to the drop down menu of Result to edit its properties in the popup dialog box.
3. Task and sub-process Table of Contents 5. Gateway
Product
Try this feature with
Visual Paradigm for UML
Technical Support
Sales Support
Discussion Forum
