Technical Support
Sales Support
Gateway is a kind of flow objects which is used to direct sequence flows within a process, base on certain condition(s). It acts like a gate that either allow or disallow passage, and possibly to control the selection of outgoing flow that pass through the gateway.
| A typical use of gateway - for modeling a situation of decision making |
There are several kinds of gateway for different kinds of control behavior, such as making decision, branching, merging, forking and joining.
| Different types of gateway |
You can optionally show the letter "X" inside the shape of exclusive gateway to distinguish it from other gateways (see the table above). To do this, right click on the background of business process diagram and select Presentation Options > Gateway Display Options > Data-Based gateway Markers Visible from the popup menu.
| 4. Event | Table of Contents | 6. Sequence and message flows |
Technical Support
Sales Support
