Table
<TableBlock>
Description
<TableBlock> is a construct that enables you to insert a table to report diagram. It is typically used to present table of elements or element properties. You must combine the use of <TableRow> and <TableCell> in order to form a complete table. Most of the build-in templates are formed by tables and contains <TableBlock>. You can look for references easily.
Attributes
Name Description/Usage Required?
tableWidth : integer The width of table, in percentage. For example: 50% means to occupy 50% of page width.
Optional
colWidths : integers Specify the widths of table columns in ratio, separate by comma. Note that the number of columns specify in @colWidths must match the number of <TableCell> to add under <TableRow>, under this table.
For example, specify "1, 1, 2" for a table with 20000 as width will result in creating a table with three columns, and have widths 5000, 5000, 10000.
Optional
alignment = center
{left | center | right}
Alignment of table. Optional
rowBackgroundColors : colors Background color of rows in table. Optional
generateHeaderOnNewPage : boolean = false When true, generate the header (the first row of this table) again if this table is generated across multiple pages. Optional
margin : integers
Specify the space around the table by providing the value of top, right, bottom, and left margins.
For example, specify "10, 20, 30, 40" for a table that has 10 as top margin, 20 as right margin, 30 as bottom margin and 40 as left margin.
Optional
margin-top : integer Specify the top margin of table. Optional
margin-right : integer Specify the right margin of table. Optional
margin-bottom : integer Specify the bottom margin of table. Optional
margin-left : integer Specify the left margin of table. Optional
Supported attributes for <TableBlock>
Sample template fragment
<Template>
    <TemplateInformationHeader name = "Classes in diagram" description = "/" type = "table" default = "false"/>
    <DiagramBaseInitiationBlock>
        <TableBlock tableWidth="10000" colWidths="1,3" alignment="right">
            <IterationBlock modelType="Class">
                <TableRow>
                    <TableCell>
                        <StringPropertyText propertyText="name"/>
                    </TableCell>
                    <TableCell>
                        <StringPropertyText propertyText="documentation"/>
                    </TableCell>
                </TableRow>
            </IterationBlock>
        </TableBlock>
    </DiagramBaseInitiationBlock>
</Template>
<TableRow>
Description
<TableRow> is a construct that enables you to add rows to a <TableBlock>. Without <TableRow>, <TableBlock> is useless. You should add <TableCell> to <TableRow> in order to complete a table.
Attributes
height : integer How tall it is for the table row.
Optional
backgroundColor : color Background color of row.
Optional
Supported attributes for <TableRow>
<Template>
                <TableRow>
                    <TableCell>
                    </TableCell>
                    <TableCell>
                    </TableCell>
                </TableRow>
            </IterationBlock>
        </TableBlock>
</Template>
<TableCell>
Description
<TableCell> is a construct that enables you to add cells to a <TableRow>.
Attributes
topBorderEnable : boolean = true True to draw the top border of cell.
Optional
bottomBorderEnable : boolean = true True to draw the bottom border of cell.
Optional
leftBorderEnable : boolean = true
True to draw the left border of cell. Optional
rightBorderEnable : boolean = true True to draw the right border of cell. Optional
color : color The background color of cell. Optional
splitted : boolean = false Determine this cell is splitted. If true, <TableRow> + <TableCell> cannot be added into this cell to make the cell splitted by more cells.
Optional
mergeColumns : integer Deprecated. Replaced by @colspan. Optional
colspan : integer Specify the number of cell this cell consumes horizontally. For example, a colspan of 2 means to consume this and the cell on the right. This is equivalent to HTML’s colspan. Optional
rowspan : integer Specify the number of cell this cell consumes vertically. For example, a rowspan of 2 means to consume this and the cell below. This is equivalent to HTML’s rowspan. Optional
Supported attributes for <TableCell>
<Template>
                <TableRow>
                    <TableCell>
                    </TableCell>
                    <TableCell>
                    </TableCell>
                </TableRow>
            </IterationBlock>
        </TableBlock>
</Template>
7. Text and break Table of Contents 9. Miscellaneous
Product
Try this feature with
Visual Paradigm for UML
Technical Support
Sales Support
Discussion Forum
