Miscellaneous
<BPProcedures>
Description
<BPProcedures> is a construct that prints in report the procedures of task/sub-process, if specified.
Attributes
Name Description/Usage Required?
tableWidth : integer The width of table.
Optional
showRowBorder : boolean = false True to draw border between rows.
Optional
showColumnBorder : boolean = true
True to draw border between columns. Optional
showName : boolean True to show the name of procedure. Optional
name : string Filter procedures by name. Optional
Supported attributes for <BPProcedures>
Sample template fragment
<Template>
    <TemplateInformationHeader name = "Procedures" description = "/" type = "table" default = "false"/>
    <ElementBaseInitiationBlock>
        <BPProcedures/>
    </ElementBaseInitiationBlock>
</Template>
<TestPlans>
Description
<TestPlans> is a construct that prints in report the test plans of a requirement test case, if specified.
Attributes
Optional
Optional
Supported attributes for <TestPlans>
<Template>
    <TemplateInformationHeader name = "Test Plans" description = "/" type = "table" default = "false"/>
        <TestPlans/>
</Template>
<TestPlanStepIterationBlock>
Description
<TestPlanStepIterationBlock> is a construct that enables you to retrieve the steps within a test plan.
<Template>
        <StringPropertyText propertyText="index" />
        <StringPropertyText propertyText="name"/>
        <StringPropertyText propertyText="expectedResults"/>
    </TestPlanStepIterationBlock>
</Template>
<MatrixDiagram>
Description
<MatrixDiagram> is a construct that prints in report the content of matrix diagram.
<Template>
    <TemplateInformationHeader name = "Matrix diagram" description = "/" type = "table" default = "false"/>
    <DiagramBaseInitiationBlock>
        <MatrixDiagram/>
    </DiagramBaseInitiationBlock>
</Template>
<GridDiagram>
Description
<GridDiagram> is a construct that prints in report a grid’s content.
Attributes
Optional
Supported attributes for <GridDiagram>
<Template>
    <TemplateInformationHeader name = "Grid" description = "/" type = "table" default = "false"/>
        <GridDiagram/>
</Template>
8. Table Table of Contents Part XIV. Interoperability and integration
Product
Try this feature with
Visual Paradigm for UML
Technical Support
Sales Support
Discussion Forum
