Publish project using project publisher
The Project Publisher is a tool that exports the project, including detailed information in diagrams and models, into interactive and well-organized web pages. The generated web pages can be read in any web browser with no additional plug-in required, so collaborative partners may see the published product even if they do not have Visual Paradigm products installed.
To launch Project Publisher:
  1. Select Tools > Project Publisher... from main menu.
  2. In the Project Publisher dialog box, specify the output directory where you want to save the published content.
  3. You can optionally configure the publisher by adjust the options or options. For details, refer to the sections below.
  4. Click OK button to start publishing.
An overview of project publisher
Overview of project publisher
No. Name Description
1 Output directory The folder where you want to publish the content to.
2 Preserve image size When checked, published content will show images in exact width and height.
3 Copy reference files You can add file references to model elements. When this option is checked, referenced files will be copied to the output directory so that you can access any referenced file when browsing the published content in other machine easily.
4 Launch viewer When checked, the system will launch the web browser and open the published Web contents.
5 Advanced options Click to configure advanced publisher options. For details about the options, read the next section.
6 OK Click to publish.
7 Cancel Click to close the dialog box without publishing.
Description of project publisher
Advanced options
On the Project Publisher dialog box you can configure some of the common options. You can also configure the advanced options for more detailed settings by clicking the Advanced Options... button.
Project publisher advanced options
Option Description
Generate model element list in diagram page
Check to generate a list of model element in a diagram page.
Generate only documentation in model element page
Check to generate only documentation in model element page, and exclude other contents.
Generate only when documentation is defined
Generate element page only when that element has documentation. When this option is off, the shape will have no linkage from image in diagram page due to the absent of element page.
Generate page header Check to generate pre-defined header.
Generate page footer Check to generate pre-defined footer.
Show documentation when hover over a shape Check to show element's documentation when moving the mouse pointer over a shape in an image of diagram.
Generate diagram type Check to generate the diagram type in addition to diagram name.
Drill down effect for general models Choose the action when pressing on model elements on a diagram.
Drill down effect for business sub-process Choose the action when pressing on sub-processes on a diagram.
Drill down effect for process (Process Map) Choose the action when pressing on processes on a process map diagram.
Drill down effect for events (BPMN) Choose the action when pressing on (BPMN) events on a diagram.
Drill down effect for diagram overview Choose the action when pressing on diagram overviews on a diagram.
Publisher engine Choose the engine for publishing. You are advised to use the new engine.
Default diagram Choose the diagram that first appear when opening the published content. If unspecified, a default page with project information will be presented.
Sort elements in type groups by Choose the way of sorting elements show in summary or drop down menu in diagram page
Filtered content Choose the content for not to show in published content
Description of project publisher advanced options
Chapter 3. Publishing project to Web Site Table of Contents 2. Using the published contents
Product
Try this feature with
Visual Paradigm for UML
Technical Support
Sales Support
Discussion Forum
