Customizing report writer template
In report writer, the templates for model elements and diagrams, such as the basic information template, are formed by XML, and can be customized. By customizing a template, you can make report writer print additional customized text, to make it query other properties you wanted, or to remove part of the unneeded content, like a row in a table.
Customizing an existing template
  1. Right click on a template and select Edit... from the popup menu.
    To edit a template
    To edit a template
  2. Edit the template in the Edit Template dialog box.
    The template editor
    The template editor
    NOTE: You can save your work from time to time by pressing Save.
  3. Click OK to confirm editing.
    NOTE: If you have chosen Refresh Report when OK, the report will refresh itself to apply the changes you have made.
Creating a template from existing template
  1. Right click on a template and select Duplicate... from the popup menu.
    To duplicate a template
  2. Fill in the Duplicate Template dialog box and click OK.
    The duplicate template dialog box
    Below is a description of the dialog box.
    Field Description
    File A template is an XML file which defines the structure of report content. By default, it will be stored in the resources folder of installation folder.
    ID The uniqie ID for template.
    Name The name of template, which will appear in the template list in template pane.
    Details of duplicate template dialog box
The template editor
The template editor is where you edit a template. The template is in XML format. Within the editor, you may make use of hotkey to perform operations like copy, paste and delete. Below is a description of common hotkeys.
Function Hotkey
Copy Ctrl-C
Paste Ctrl-V
Delete Delete
Cut Ctrl-X
Hotkeys for template editor
As most of the templates are in tabular forms. We recommend users who want to add new rows to highlight and copy a trunk of row content...
Select existing content to copy and start editing
and edit the custom text and properties to query.
Template content with respect to report content
Template schema
<?xml version="1.0" encoding="UTF-8"?>
<xsd:schema
        targetNamespace="http://www.visual-paradigm.com/2008/ReportWriter1.1"
        xmlns:rw="http://www.visual-paradigm.com/2008/ReportWriter1.1"
        xmlns:xsd="http://www.w3.org/2001/XMLSchema" elementFormDefault="qualified" attributeFormDefault="unqualified">
    <xsd:element name="Template">
        <xsd:complexType>
            <xsd:sequence>
                <xsd:element ref="rw:TemplateInformationHeader"/>
                <xsd:choice>
                    <xsd:element ref="rw:ElementBaseInitiationBlock"/>
                    <xsd:element ref="rw:DiagramBaseInitiationBlock"/>
                    <xsd:element ref="rw:DiagramElementBaseInitiationBlock"/>
                    <xsd:element ref="rw:ProjectBaseInitiationBlock"/>
                </xsd:choice>
            </xsd:sequence>
        </xsd:complexType>
    </xsd:element>
    <xsd:element name="TemplateInformationHeader">
        <xsd:complexType>
            <xsd:attribute name="id" type="xsd:string" use="optional"/>
            <xsd:attribute name="name" type="xsd:string" use="required"/>
            <xsd:attribute name="description" type="xsd:string" use="optional"/>
            <xsd:attribute name="default" type="xsd:boolean" use="optional" default="false"/>
            <xsd:attribute name="type" use="optional" default="text">
                <xsd:simpleType>
                    <xsd:restriction base="xsd:NMTOKEN">
                        <xsd:enumeration value="text"/>
                        <xsd:enumeration value="image"/>
                        <xsd:enumeration value="table"/>
                    </xsd:restriction>
                </xsd:simpleType>
            </xsd:attribute>
        </xsd:complexType>
    </xsd:element>
    <xsd:element name="ElementBaseInitiationBlock">
        <xsd:complexType>
            <xsd:sequence>
                <!-- any element after the comment "CONTENTS"-->
                <xsd:any minOccurs="1" maxOccurs="unbounded"/>
            </xsd:sequence>
        </xsd:complexType>
    </xsd:element>
    <xsd:element name="DiagramBaseInitiationBlock">
        <xsd:complexType>
            <xsd:sequence>
            </xsd:sequence>
        </xsd:complexType>
    </xsd:element>
    <xsd:element name="DiagramElementBaseInitiationBlock">
        <xsd:complexType>
            <xsd:sequence>
            </xsd:sequence>
        </xsd:complexType>
    </xsd:element>
    <xsd:element name="ProjectBaseInitiationBlock">
        <xsd:complexType>
            <xsd:sequence>
            </xsd:sequence>
        </xsd:complexType>
    </xsd:element>
    <!-- CONTENTS -->
    <!-- Breaks, Text -->
    <xsd:element name="ParagraphBreak"/>
    <xsd:element name="PageBreak"/>
    <xsd:element name="StaticText">
        <xsd:complexType>
            <xsd:attribute name="content" type="xsd:string" use="optional"/>
            <xsd:attribute name="isBold" type="xsd:boolean" use="optional" default="false"/>
            <xsd:attribute name="isItalic" type="xsd:boolean" use="optional" default="false"/>
            <xsd:attribute name="fontFamily" type="xsd:string" use="optional" default="Times New Roman"/>
            <xsd:attribute name="alignment" use="optional" default="left">
                <xsd:simpleType>
                        <xsd:enumeration value="left"/>
                        <xsd:enumeration value="center"/>
                        <xsd:enumeration value="right"/>
                    </xsd:restriction>
                </xsd:simpleType>
            </xsd:attribute>
            <xsd:attribute name="fontSize" type="xsd:integer" use="optional" default="12"/>
            <xsd:attribute name="style" type="xsd:string" use="optional"/>
            <xsd:attribute name="numberingLevel" type="xsd:short" use="optional"/>
            <xsd:attribute name="foreColor" type="rw:color" use="optional"/>
            <xsd:attribute name="indentation" type="xsd:double" use="optional"/>
        </xsd:complexType>
    </xsd:element>
    <!-- Table -->
    <xsd:element name="TableBlock">
        <xsd:complexType>
            <xsd:sequence>
                <xsd:element ref="rw:TableRow" minOccurs="0" maxOccurs="unbounded"/>
            </xsd:sequence>
            <xsd:attribute name="tableWidth" type="xsd:integer" use="optional" default="10000">
                <xsd:annotation>
                    <xsd:documentation>Document is in A4 size (21000*27000)</xsd:documentation>
                </xsd:annotation>
            </xsd:attribute>
            <xsd:attribute name="colWidths" type="rw:integers" use="optional">
                <xsd:annotation>
                    <xsd:documentation>
                    @colWidths is relative to @tableWidth.
                    For example,  tableWidth="15000" colWidths="10, 20, 70", finally the columns widths will be:
                    1500 (15000*10/(10+20+70))
                    3000 (15000*20/(10+20+70))
                    10500  (15000*70/(10+20+70))
                </xsd:annotation>
            </xsd:attribute>
            <xsd:attribute name="alignment"  use="optional" default="center">
                <xsd:simpleType>
                    </xsd:restriction>
                </xsd:simpleType>
            </xsd:attribute>
            <xsd:attribute name="rowBackgroundColors" type="rw:colors" use="optional"/>
        </xsd:complexType>
    </xsd:element>
    <xsd:element name="TableRow">
        <xsd:complexType>
            <xsd:sequence>
                <xsd:element ref="rw:TableCell" minOccurs="0" maxOccurs="unbounded"/>
            </xsd:sequence>
            <xsd:attribute name="height" type="xsd:integer" use="optional"/>
            <xsd:attribute name="backgroundColor" type="rw:color" use="optional"/>
        </xsd:complexType>
    </xsd:element>
    <xsd:element name="TableCell">
        <xsd:complexType>
            <xsd:sequence>
            </xsd:sequence>
            <xsd:attribute name="topBorderEnable" type="xsd:boolean" use="optional" default="true"/>
            <xsd:attribute name="bottomBorderEnable" type="xsd:boolean" use="optional" default="true"/>
            <xsd:attribute name="leftBorderEnable" type="xsd:boolean" use="optional" default="true"/>
            <xsd:attribute name="rightBorderEnable" type="xsd:boolean" use="optional" default="true"/>
            <xsd:attribute name="color" type="rw:color" use="optional"/>
            <xsd:attribute name="splitted" type="xsd:boolean" use="optional" default="false"/>
        </xsd:complexType>
    </xsd:element>
    Iteration, retrieve a list of values
    (IterationBlock, ForEach, ForEachSimpleRelationship, ForEachRelationshipEnd, ForEachSubDiagram, ForEachOwnerDiagram, ForEachDiagram)
    <xsd:element name="IterationBlock">
        <xsd:annotation>
            <xsd:documentation>
            Retrieve children from Project/Model/Diagram/DiagramElement.
            Project and Model will be retrieved children Model.
            Diagram and DiagramElement will be retrieved children DiagramElement.
        </xsd:annotation>
        <xsd:complexType>
            <xsd:sequence>
            </xsd:sequence>
            <xsd:attribute name="elementType" type="xsd:string" use="optional">
                <xsd:annotation>
                    <xsd:documentation>Deprecated, replaced by @modelType (Model's modelType or DiagramElement's shapeType)</xsd:documentation>
                </xsd:annotation>
            </xsd:attribute>
            <xsd:attribute name="modelType" type="xsd:string" use="optional">
                <xsd:annotation>
                    <xsd:documentation>Filter children by modelType.</xsd:documentation>
                </xsd:annotation>
            </xsd:attribute>
            <xsd:attribute name="elementTypes" type="rw:strings" use="optional">
                <xsd:annotation>
                    <xsd:documentation>Deprecated, replaced by @modelTypes (Model's modelTypes or DiagramElement's shapeTypes)</xsd:documentation>
                </xsd:annotation>
            </xsd:attribute>
            <xsd:attribute name="modelTypes" type="rw:strings" use="optional">
                <xsd:annotation>
                    <xsd:documentation>Filter children by modelTypes. If @modelType is defined, @modelTypes will be ignored.</xsd:documentation>
                </xsd:annotation>
            </xsd:attribute>
            <xsd:attribute name="name" type="xsd:string" use="optional">
                <xsd:annotation>
                    <xsd:documentation>Filter children by name.</xsd:documentation>
                </xsd:annotation>
            </xsd:attribute>
            <xsd:attribute name="filterHidden" type="xsd:boolean" use="optional" default="false">
                <xsd:annotation>
                    <xsd:documentation>
                    Filter hidden children DiagramElement.
                    For retrieve from Diagram/DiagramElement only.
                </xsd:annotation>
            </xsd:attribute>
            <xsd:attribute name="includeConnector" type="xsd:boolean" use="optional" default="false">
                <xsd:annotation>
                    <xsd:documentation>Deprecated, replaced by @includeConnectors</xsd:documentation>
                </xsd:annotation>
            </xsd:attribute>
            <xsd:attribute name="includeConnectors" type="xsd:boolean" use="optional" default="false">
                <xsd:annotation>
                    <xsd:documentation>
                    Retrieve Shape+Connector from Diagram. Otherwise, only the Shape will retrived.
                    For retrieve from Diagram only.
                </xsd:annotation>
            </xsd:attribute>
            <xsd:attribute name="byBounds" type="xsd:boolean" use="optional" default="false">
                <xsd:annotation>
                    <xsd:documentation>
                    Retrieve DiagramElement by Bounds.
                    sometimes, the parent shape "contains" another shape. But another shape is not child of the shape.
                    e.g. BPGroup won't be parent of the shapes.
                </xsd:annotation>
            </xsd:attribute>
            <xsd:attribute name="byBoundsInAllLevel" type="xsd:boolean" use="optional" default="false"/>
            <xsd:attribute name="allLevel" type="xsd:boolean" use="optional" default="false">
                <xsd:annotation>
                    <xsd:documentation>
                    Retrieve all models of the project. Otherwise, only the "root level models (models have no parent model)" will be retrieved.
                    For retrieve from Project only.
                </xsd:annotation>
            </xsd:attribute>
            <xsd:attribute name="ignoreParagraphBreakForLastModel" type="xsd:boolean" use="optional" default="false"/>
            <xsd:attribute name="breakString" type="xsd:string" use="optional"/>
            <xsd:attribute name="sortBy" type="xsd:NMTOKEN" use="optional">
                <xsd:annotation>
                    <xsd:documentation>Deprecated, replaced by @sortBys</xsd:documentation>
                </xsd:annotation>
            </xsd:attribute>
            <xsd:attribute name="sortBys" type="rw:strings" use="optional">
                <xsd:annotation>
                    <xsd:documentation>
                    Sort by following options:
                    name | modelType | property
                </xsd:annotation>
            </xsd:attribute>
            <xsd:attribute name="sortProperty" type="xsd:string" use="optional">
                <xsd:annotation>
                    <xsd:documentation>
                    If sort by property, @sortProperty is required to specified sort by which property
                </xsd:annotation>
            </xsd:attribute>
            <xsd:attribute name="sortValues" type="rw:strings" use="optional">
                <xsd:annotation>
                    <xsd:documentation>
                    If sort by property, @sortValues can be specified for sort by values of the property
                </xsd:annotation>
            </xsd:attribute>
            <xsd:attribute name="defaultPropertyValue" type="xsd:string" use="optional">
                <xsd:annotation>
                    <xsd:documentation>
                    If sort by property, @defaultPropertyValue can be specified for the default value of the model has no this property value
                </xsd:annotation>
            </xsd:attribute>
            <xsd:attribute name="descendingSort" type="xsd:boolean" use="optional" default="false">
                <xsd:annotation>
                    <xsd:documentation>Deprecated, replaced by @descendingSort</xsd:documentation>
                </xsd:annotation>
            </xsd:attribute>
            <xsd:attribute name="descendingSorts" type="rw:booleans" use="optional">
                <xsd:annotation>
                    <xsd:documentation>
                    Sorting in descending order?
                    numbers of descendingSorts should be same as sortBys
                    e.g. @sortBy="name, modelType" @descendingSorts="true, false"
                    then, sort by name will be descending, sort by modelType will be ascending
                </xsd:annotation>
            </xsd:attribute>
            <xsd:attribute name="identifier" type="xsd:string" use="optional"/>
        </xsd:complexType>
    </xsd:element>
    <xsd:element name="ForEach">
        <xsd:annotation>
            <xsd:documentation>Retrieve Model values from Model's property.</xsd:documentation>
        </xsd:annotation>
        <xsd:complexType>
            <xsd:sequence>
            </xsd:sequence>
            <xsd:attribute name="property" type="xsd:string" use="optional">
                <xsd:annotation>
                    <xsd:documentation>Retrieve from which proprety.</xsd:documentation>
                </xsd:annotation>
            </xsd:attribute>
                <xsd:annotation>
                </xsd:annotation>
            </xsd:attribute>
                <xsd:annotation>
                    <xsd:documentation>
                    if sort by property, @sortProperty is required to specified sort by which property
                </xsd:annotation>
            </xsd:attribute>
                <xsd:annotation>
                    <xsd:documentation>
                </xsd:annotation>
            </xsd:attribute>
                <xsd:annotation>
                    <xsd:documentation>
                </xsd:annotation>
            </xsd:attribute>
                <xsd:annotation>
                    <xsd:documentation>
                </xsd:annotation>
            </xsd:attribute>
                <xsd:annotation>
                </xsd:annotation>
            </xsd:attribute>
                <xsd:annotation>
                    <xsd:documentation>
                </xsd:annotation>
            </xsd:attribute>
        </xsd:complexType>
    </xsd:element>
    <xsd:element name="ForEachSimpleRelationship">
        <xsd:annotation>
            <xsd:documentation>Retrieve SimpleRelationship from Model, or Connector from DiagramElement</xsd:documentation>
        </xsd:annotation>
        <xsd:complexType>
            <xsd:sequence>
            </xsd:sequence>
            <xsd:attribute name="type" type="xsd:string" use="optional">
                <xsd:annotation>
                </xsd:annotation>
            </xsd:attribute>
                <xsd:annotation>
                    <xsd:documentation>Filter relationships by modelType.</xsd:documentation>
                </xsd:annotation>
            </xsd:attribute>
                <xsd:annotation>
                    <xsd:documentation>Filter relationships by modelTypes. If @modelType is defined, @modelTypes will be ignored.</xsd:documentation>
                </xsd:annotation>
            </xsd:attribute>
            <xsd:attribute name="direction" use="optional">
                <xsd:annotation>
                    <xsd:documentation>Filter relationship by direction.</xsd:documentation>
                </xsd:annotation>
                <xsd:simpleType>
                        <xsd:enumeration value="all"/>
                        <xsd:enumeration value="from"/>
                        <xsd:enumeration value="to"/>
                    </xsd:restriction>
                </xsd:simpleType>
            </xsd:attribute>
                <xsd:annotation>
                </xsd:annotation>
            </xsd:attribute>
                <xsd:annotation>
                    <xsd:documentation>
                </xsd:annotation>
            </xsd:attribute>
                <xsd:annotation>
                    <xsd:documentation>
                </xsd:annotation>
            </xsd:attribute>
                <xsd:annotation>
                    <xsd:documentation>
                </xsd:annotation>
            </xsd:attribute>
                <xsd:annotation>
                    <xsd:documentation>
                </xsd:annotation>
            </xsd:attribute>
                <xsd:annotation>
                </xsd:annotation>
            </xsd:attribute>
                <xsd:annotation>
                    <xsd:documentation>
                </xsd:annotation>
            </xsd:attribute>
        </xsd:complexType>
    </xsd:element>
    <xsd:element name="ForEachRelationshipEnd">
        <xsd:annotation>
        </xsd:annotation>
        <xsd:complexType>
            <xsd:sequence>
            </xsd:sequence>
                <xsd:annotation>
                </xsd:annotation>
            </xsd:attribute>
                <xsd:annotation>
                </xsd:annotation>
            </xsd:attribute>
                <xsd:annotation>
                </xsd:annotation>
            </xsd:attribute>
            <xsd:attribute name="endPointer" use="optional">
                <xsd:annotation>
                    <xsd:documentation>
                    both = all, self = from, other = to
                </xsd:annotation>
                <xsd:simpleType>
                        <xsd:enumeration value="both"/>
                        <xsd:enumeration value="self"/>
                        <xsd:enumeration value="other"/>
                    </xsd:restriction>
                </xsd:simpleType>
            </xsd:attribute>
                <xsd:annotation>
                </xsd:annotation>
            </xsd:attribute>
                <xsd:annotation>
                    <xsd:documentation>
                </xsd:annotation>
            </xsd:attribute>
                <xsd:annotation>
                    <xsd:documentation>
                </xsd:annotation>
            </xsd:attribute>
                <xsd:annotation>
                    <xsd:documentation>
                </xsd:annotation>
            </xsd:attribute>
                <xsd:annotation>
                    <xsd:documentation>
                </xsd:annotation>
            </xsd:attribute>
                <xsd:annotation>
                </xsd:annotation>
            </xsd:attribute>
                <xsd:annotation>
                    <xsd:documentation>
                </xsd:annotation>
            </xsd:attribute>
        </xsd:complexType>
    </xsd:element>
    <xsd:element name="ForEachSubDiagram">
        <xsd:annotation>
            <xsd:documentation>Retrieve sub diagrams from Model</xsd:documentation>
        </xsd:annotation>
        <xsd:complexType>
            <xsd:sequence>
            </xsd:sequence>
            <xsd:attribute name="diagramType" type="xsd:string" use="optional">
                <xsd:annotation>
                    <xsd:documentation>Filter diagram by diagramType.</xsd:documentation>
                </xsd:annotation>
            </xsd:attribute>
                <xsd:annotation>
                </xsd:annotation>
            </xsd:attribute>
                <xsd:annotation>
                    <xsd:documentation>
                </xsd:annotation>
            </xsd:attribute>
                <xsd:annotation>
                    <xsd:documentation>
                </xsd:annotation>
            </xsd:attribute>
                <xsd:annotation>
                    <xsd:documentation>
                </xsd:annotation>
            </xsd:attribute>
                <xsd:annotation>
                    <xsd:documentation>
                </xsd:annotation>
            </xsd:attribute>
                <xsd:annotation>
                </xsd:annotation>
            </xsd:attribute>
                <xsd:annotation>
                    <xsd:documentation>
                </xsd:annotation>
            </xsd:attribute>
        </xsd:complexType>
    </xsd:element>
    <xsd:element name="ForEachOwnerDiagram">
        <xsd:annotation>
            <xsd:documentation>Retrieve owner diagrams which the Model is shown on</xsd:documentation>
        </xsd:annotation>
        <xsd:complexType>
            <xsd:sequence>
            </xsd:sequence>
                <xsd:annotation>
                </xsd:annotation>
            </xsd:attribute>
                <xsd:annotation>
                </xsd:annotation>
            </xsd:attribute>
                <xsd:annotation>
                    <xsd:documentation>
                </xsd:annotation>
            </xsd:attribute>
                <xsd:annotation>
                    <xsd:documentation>
                </xsd:annotation>
            </xsd:attribute>
                <xsd:annotation>
                    <xsd:documentation>
                </xsd:annotation>
            </xsd:attribute>
                <xsd:annotation>
                    <xsd:documentation>
                </xsd:annotation>
            </xsd:attribute>
                <xsd:annotation>
                </xsd:annotation>
            </xsd:attribute>
                <xsd:annotation>
                    <xsd:documentation>
                </xsd:annotation>
            </xsd:attribute>
        </xsd:complexType>
    </xsd:element>
    <xsd:element name="ForEachDiagram">
        <xsd:annotation>
            <xsd:documentation>Retrieve diagrams from Project</xsd:documentation>
        </xsd:annotation>
        <xsd:complexType>
            <xsd:sequence>
            </xsd:sequence>
                <xsd:annotation>
                </xsd:annotation>
            </xsd:attribute>
                <xsd:annotation>
                </xsd:annotation>
            </xsd:attribute>
                <xsd:annotation>
                    <xsd:documentation>
                </xsd:annotation>
            </xsd:attribute>
                <xsd:annotation>
                    <xsd:documentation>
                </xsd:annotation>
            </xsd:attribute>
                <xsd:annotation>
                    <xsd:documentation>
                </xsd:annotation>
            </xsd:attribute>
                <xsd:annotation>
                    <xsd:documentation>
                </xsd:annotation>
            </xsd:attribute>
                <xsd:annotation>
                </xsd:annotation>
            </xsd:attribute>
                <xsd:annotation>
                    <xsd:documentation>
                </xsd:annotation>
            </xsd:attribute>
        </xsd:complexType>
    </xsd:element>
     Conditional, if condition not match, children template node won't be executed
     (DefaultConditionChecker, ValueConditionChecker, HasChildElementChecker, HasMetaModelPropertyChecker, HasParentModelChecker, HasRelationshipChecker, ReportOptionChecker, HasDiagramChecker)
    <xsd:element name="DefaultConditionChecker">
        <xsd:annotation>
            <xsd:documentation>Check property value equals to its default value.</xsd:documentation>
        </xsd:annotation>
        <xsd:complexType>
            <xsd:sequence>
            </xsd:sequence>
            <xsd:attribute name="equalFlag" type="xsd:boolean" use="optional" default="false">
                <xsd:annotation>
                    <xsd:documentation>Deprecated, replaced by @flag</xsd:documentation>
                </xsd:annotation>
            </xsd:attribute>
            <xsd:attribute name="flag" type="xsd:boolean" use="optional" default="false"/>
        </xsd:complexType>
    </xsd:element>
    <xsd:element name="ValueConditionChecker">
        <xsd:annotation>
            <xsd:documentation>Check property value.</xsd:documentation>
        </xsd:annotation>
        <xsd:complexType>
            <xsd:sequence>
            </xsd:sequence>
            <xsd:attribute name="propertyType" use="optional" default="string">
                <xsd:simpleType>
                        <xsd:enumeration value="string"/>
                        <xsd:enumeration value="int"/>
                        <xsd:enumeration value="boolean"/>
                        <xsd:enumeration value="model"/>
                    </xsd:restriction>
                </xsd:simpleType>
            </xsd:attribute>
            <xsd:attribute name="operator" use="required">
                <xsd:annotation>
                    <xsd:documentation>
                    "equal" is deprecated, replaced by "equals"
                    "not equal" is deprecated, replaced by "not equals"
                    "equals", "not equals" for string/int/boolean/model property
                    "less than", "equals or less than", "greater than", "equals or greater than" for string/int property
                    "like", "not like" for string property
                </xsd:annotation>
                <xsd:simpleType>
                    <xsd:restriction base="xsd:string">
                        <xsd:enumeration value="equals"/>
                        <xsd:enumeration value="not equals"/>
                        <xsd:enumeration value="less than"/>
                        <xsd:enumeration value="equals or less than"/>
                        <xsd:enumeration value="greater than"/>
                        <xsd:enumeration value="equals or greater than"/>
                        <xsd:enumeration value="like"/>
                        <xsd:enumeration value="not like"/>
                        <xsd:enumeration value="equal"/>
                        <xsd:enumeration value="not equal"/>
                    </xsd:restriction>
                </xsd:simpleType>
            </xsd:attribute>
            <xsd:attribute name="expectedValue" type="xsd:string" use="optional"/>
            <xsd:attribute name="caseSensitive" type="xsd:boolean" use="optional" default="true">
                <xsd:annotation>
                    <xsd:documentation>Case sensitive/insensitive for string property</xsd:documentation>
                </xsd:annotation>
            </xsd:attribute>
        </xsd:complexType>
    </xsd:element>
    <xsd:element name="HasChildElementChecker">
        <xsd:complexType>
            <xsd:sequence>
            </xsd:sequence>
            <xsd:attribute name="flag" type="xsd:boolean" use="optional" default="true"/>
                <xsd:annotation>
                    <xsd:documentation>Deprecated, replaced by @modelType</xsd:documentation>
                </xsd:annotation>
            </xsd:attribute>
            <xsd:attribute name="modelType" type="xsd:string" use="optional"/>
            <xsd:attribute name="elementTypes" type="xsd:string" use="optional">
                <xsd:annotation>
                    <xsd:documentation>Deprecated, replaced by @modelTypes</xsd:documentation>
                </xsd:annotation>
            </xsd:attribute>
            <xsd:attribute name="modelTypes" type="xsd:string" use="optional"/>
                <xsd:annotation>
                </xsd:annotation>
            </xsd:attribute>
                <xsd:annotation>
                    <xsd:documentation>
                </xsd:annotation>
            </xsd:attribute>
                <xsd:annotation>
                    <xsd:documentation>
                </xsd:annotation>
            </xsd:attribute>
        </xsd:complexType>
    </xsd:element>
    <xsd:element name="HasMetaModelPropertyChecker">
        <xsd:complexType>
            <xsd:sequence>
            </xsd:sequence>
            <xsd:attribute name="property" type="xsd:string" use="required"/>
        </xsd:complexType>
    </xsd:element>
    <xsd:element name="HasParentModelChecker">
        <xsd:complexType>
            <xsd:sequence>
            </xsd:sequence>
        </xsd:complexType>
    </xsd:element>
    <xsd:element name="HasRelationshipChecker">
        <xsd:complexType>
            <xsd:sequence>
            </xsd:sequence>
                <xsd:annotation>
                </xsd:annotation>
            </xsd:attribute>
            <xsd:attribute name="direction" use="optional" default="all">
                <xsd:annotation>
                    <xsd:documentation>
                    self_begins, self_ends are deprecated
                    self_begins = from
                    self_ends = to
                </xsd:annotation>
                <xsd:simpleType>
                        <xsd:enumeration value="self_begins"/>
                        <xsd:enumeration value="self_ends"/>
                    </xsd:restriction>
                </xsd:simpleType>
            </xsd:attribute>
        </xsd:complexType>
    </xsd:element>
    <xsd:element name="ReportOptionChecker">
        <xsd:complexType>
            <xsd:sequence>
            </xsd:sequence>
                <xsd:annotation>
                </xsd:annotation>
            </xsd:attribute>
            <xsd:attribute name="option" type="xsd:string" use="optional">
                <xsd:annotation>
                    <xsd:documentation>
                    Check the option. Now, only one option is supported. Which is:
                    basicInformationShowsDocumentation
                    user can switch the option on Report Writer main menu: Tool &gt; Options &gt;
                </xsd:annotation>
            </xsd:attribute>
        </xsd:complexType>
    </xsd:element>
    <xsd:element name="HasDiagramChecker">
        <xsd:complexType>
            <xsd:sequence>
            </xsd:sequence>
                <xsd:annotation>
                    <xsd:documentation>Deprecated, replaced by @diagramType</xsd:documentation>
                </xsd:annotation>
            </xsd:attribute>
            <xsd:attribute name="diagramType" type="xsd:string" use="optional"/>
        </xsd:complexType>
    </xsd:element>
    Property, getting property value from model
    (StringPropertyText, IntPropertyText, BooleanPropertyText, MetaModelElement, FromEnd, ToEnd, RelationshipEndEndRelationship, RelationshipEndOppositeEnd, ParentModel, DiagramProperty)
    <xsd:element name="StringPropertyText">
        <xsd:complexType>
            <xsd:attribute name="propertyText" type="xsd:string" use="optional">
                <xsd:annotation>
                    <xsd:documentation>Deprecated, replaced by @property</xsd:documentation>
                </xsd:annotation>
            </xsd:attribute>
            <xsd:attribute name="isHTML" type="xsd:boolean" use="optional" default="false"/>
            <xsd:attribute name="forcePlainText" type="xsd:boolean" use="optional" default="false"/>
            <xsd:attribute name="defaultValue" type="xsd:string" use="optional"/>
            <xsd:attribute name="property" type="xsd:string" use="optional"/>
                <xsd:simpleType>
                    </xsd:restriction>
                </xsd:simpleType>
            </xsd:attribute>
        </xsd:complexType>
    </xsd:element>
    <xsd:element name="IntPropertyText">
        <xsd:complexType>
                <xsd:annotation>
                </xsd:annotation>
            </xsd:attribute>
                <xsd:simpleType>
                    </xsd:restriction>
                </xsd:simpleType>
            </xsd:attribute>
        </xsd:complexType>
    </xsd:element>
    <xsd:element name="BooleanPropertyText">
        <xsd:complexType>
                <xsd:annotation>
                </xsd:annotation>
            </xsd:attribute>
                <xsd:simpleType>
                    </xsd:restriction>
                </xsd:simpleType>
            </xsd:attribute>
        </xsd:complexType>
    </xsd:element>
    <xsd:element name="MetaModelElement">
        <xsd:annotation>
            <xsd:documentation>Retrieve Model from property.</xsd:documentation>
        </xsd:annotation>
        <xsd:complexType>
            <xsd:attribute name="mode" type="xsd:boolean" use="optional" default="true"/>
            <xsd:attribute name="modelProperty" type="xsd:string" use="optional">
                <xsd:annotation>
                </xsd:annotation>
            </xsd:attribute>
        </xsd:complexType>
    </xsd:element>
    <xsd:element name="FromEnd">
        <xsd:annotation>
            <xsd:documentation>Retrieve From RelationshipEnd from EndRelationship, or From model from SimpleRelationship.</xsd:documentation>
        </xsd:annotation>
    </xsd:element>
    <xsd:element name="ToEnd">
        <xsd:annotation>
            <xsd:documentation>Retrieve To RelationshipEnd from EndRelationship, or To model from SimpleRelationship.</xsd:documentation>
        </xsd:annotation>
    </xsd:element>
    <xsd:element name="RelationshipEndEndRelationship">
        <xsd:annotation>
            <xsd:documentation>Retrieve EndRelationship from RelationshipEnd.</xsd:documentation>
        </xsd:annotation>
    </xsd:element>
    <xsd:element name="RelationshipEndOppositeEnd">
        <xsd:annotation>
            <xsd:documentation>Retrieve opposite end from RelationshipEnd.</xsd:documentation>
        </xsd:annotation>
    </xsd:element>
    <xsd:element name="ParentModel">
        <xsd:annotation>
            <xsd:documentation>Retrieve parent model from Model.</xsd:documentation>
        </xsd:annotation>
    </xsd:element>
    <xsd:element name="DiagramProperty">
        <xsd:annotation>
            <xsd:documentation>Retrieve diagram from property. e.g. BPSubProcess.diagramId refer its bpd.</xsd:documentation>
        </xsd:annotation>
        <xsd:complexType>
        </xsd:complexType>
    </xsd:element>
    Others
    (ElementImage, FlowOfEventsTemplate)
    <xsd:element name="ElementImage">
        <xsd:annotation>
            <xsd:documentation>Showing image of Diagram/DiagramElement, or icon for model type.</xsd:documentation>
        </xsd:annotation>
        <xsd:complexType>
            <xsd:attribute name="imageType" use="optional" default="icon">
                <xsd:annotation>
                    <xsd:documentation>
                    "diagram" means show image for Diagram/DiagramElement
                    "icon" means show icon for the model type
                </xsd:annotation>
                <xsd:simpleType>
                        <xsd:enumeration value="diagram"/>
                        <xsd:enumeration value="icon"/>
                    </xsd:restriction>
                </xsd:simpleType>
            </xsd:attribute>
                <xsd:simpleType>
                    </xsd:restriction>
                </xsd:simpleType>
            </xsd:attribute>
            <xsd:attribute name="width" type="xsd:integer" use="optional"/>
            <xsd:attribute name="maxWidth" type="xsd:integer" use="optional"/>
            <xsd:attribute name="maxHeight" type="xsd:integer" use="optional"/>
        </xsd:complexType>
    </xsd:element>
    <xsd:element name="FlowOfEventsTemplate">
        <xsd:annotation>
            <xsd:documentation>Showing Flow Of Events for a Use Case.</xsd:documentation>
        </xsd:annotation>
        <xsd:complexType>
            <xsd:attribute name="showProcedure" use="optional" default="follow model">
                <xsd:simpleType>
                        <xsd:enumeration value="follow model"/>
                        <xsd:enumeration value="true"/>
                        <xsd:enumeration value="false"/>
                    </xsd:restriction>
                </xsd:simpleType>
            </xsd:attribute>
            <xsd:attribute name="tableWidth" type="xsd:integer" use="optional" default="15500"/>
            <xsd:attribute name="showRowBorder" type="xsd:boolean" use="optional" default="false"/>
            <xsd:attribute name="showColumnBorder" type="xsd:boolean" use="optional" default="true"/>
            <xsd:attribute name="showName" type="xsd:boolean" use="optional" default="true">
                <xsd:annotation>
                    <xsd:documentation>Show the name of Flow of event?</xsd:documentation>
                </xsd:annotation>
            </xsd:attribute>
            <xsd:attribute name="columnWidths" type="rw:integers" use="optional"/>
                <xsd:annotation>
                    <xsd:documentation>Filter Flow of events by name.</xsd:documentation>
                </xsd:annotation>
            </xsd:attribute>
        </xsd:complexType>
    </xsd:element>
    <xsd:simpleType name="strings">
        <xsd:annotation>
            <xsd:documentation>Strings separated by ", ". e.g. "Class, UseCase, Actor" means "Class", "UseCase", "Actor"</xsd:documentation>
        </xsd:annotation>
        <xsd:restriction base="xsd:string"/>
    </xsd:simpleType>
    <xsd:simpleType name="integers">
        <xsd:annotation>
            <xsd:documentation>Integers separated by ", ". e.g. "10, 20, 70"</xsd:documentation>
        </xsd:annotation>
    </xsd:simpleType>
    <xsd:simpleType name="booleans">
        <xsd:annotation>
            <xsd:documentation>Booleans separated by ", ". e.g. "true, false, false"</xsd:documentation>
        </xsd:annotation>
    </xsd:simpleType>
    <xsd:simpleType name="color">
        <xsd:annotation>
            <xsd:documentation>
            Color can be represented in following 2 forms:
            1. "R, G, B" in decimal, e.g. "230, 230, 230" (it is a light gray color)
            2. #FFFFFF (RGB in hexadecimal), e.g. #FF0000 (it is a red color)
            Prefer using #FFFFFF. Because "R, G, B" is not suitable for colors.
        </xsd:annotation>
    </xsd:simpleType>
    <xsd:simpleType name="colors">
        <xsd:annotation>
            <xsd:documentation>
            Colors separated by ", ". e.g. "#FF0000, #00FF00, #0000FF".
        </xsd:annotation>
    </xsd:simpleType>
</xsd:schema>
6. Export and import report Table of Contents 8. Printing in Report Writer
Product
Try this feature with
Visual Paradigm for UML
Technical Support
Sales Support
Discussion Forum
