Export and import report
You can export report as file and edit it outside VP-UML. Supported format includes Microsoft Word and OpenOffice.org Text Document.
Exporting current report
  1. Click on the Export Report... button on the toolbar or select Report > Export Report... from main menu. This display the Save dialog box.
  2. In the Save dialog box, enter the file name and select the format for exporting.
  3. Click Save to export the report.
Exporting all report(s)
  1. Click the Export All Reports... button on the toolbar or select Report > Export All Reports... from main menu. This display the Save dialog box.
  2. In the Save dialog box, enter the directory for storing the reports in the File name field and select the Document Type.
  3. When everything is ready, click Save to export the report(s).
Importing a report
You can import a document back into Report Writer for data updating. To import a report:
  1. Click the Import Report... button on the toolbar or select Report > Import Report... from main menu. This displays the Open dialog box.
  2. Select a file and click Open to import the selected document into Report Writer.
  3. If the document has previously been exported from Report Writer, a dialog will appear and ask for overwriting the existing one or not.
    Confirm overwrite existing report
    If you click Yes, the existing report will be replaced by the imported one. If you click No, the imported report will be stored into Report.
5. Updating report content Table of Contents 7. Customizing Report Writer Template
Product
Try this feature with
Visual Paradigm for UML
Technical Support
Sales Support
Discussion Forum
