Technical Support
Sales Support
Report generation is the process of producing a report for sharing your design work and model specification with teammates and clients. You can generate reports in different formats such as HTML, PDF or MS Word for reading or publishing in different environments. They differ in file format, but have the same layout. In this chapter, we will go through the core steps in report generation.
To generate a report:
| NOTE: | For HTML report, specify the folder of the HTML files to be generated. For PDF report, specify the file path of PDF file (*.pdf) to be generated. For MS Word report, specify the file path of the document file (*.docx) to be generated. |
| Select diagram to include in report |
| Overview of report generation dialog box |
| The bottom part of report generaition dialog box for MS Word report |
| Description of report generation dialog box |
At the bottom of the MS Word report generation dialog box, there is an option Word template path, with a text box next to it for filling in the path of template file. A Word template file provides the start up contents and defines the style of report. During report generation, the generator will make a copy of the template file, treat the copied file as base, append the generated content to the copied file, and save the file to the destination path. By using a word template, you can define your own headers/footers, cover page, start up content, styles for your generated report.
| A generated report with style defined in template applied |
By default, diagrams show in report follows the order defined in diagram tree in the Generate PDF dialog box. We may, however, sort the diagrams to make them appear in desired sequence. To sort diagram(s), select the diagram(s) to be ordered on the list at the center of dialog box, and click
or
to sort.
| Reorder diagram |
| Sort shapes |
| Select the way to sort shape |
| Different ways of sorting |
| Chapter 1. Generating HTML/PDF/Word report | Table of Contents | 2. Configuring report |
Technical Support
Sales Support
