Technical Support
Sales Support
VP-UML enables you to build a chart. In addition to the built-in RACI chart available for general purposes, you can define your own type of chart for problem-specific purposes. In this page, you can learn how to develop a chart, define color for roles and define a new code type.
| Create new chart diagram |
| Name the chart diagram |
| Select a model element type for row and column |
| NOTE: | The choice of model element types will be in accordance with your exisiting model elements in the same project. |
| Click Mark Code to Cell button |
| Assign role |
Apart from selecting existing model elements on chart, you can also create objects without model view. Those objects will have the similar properties with model elements, which you can assign role to them.
To create an item without model view:
| Add an item |
| Enter item's name |
| The newly created item is shown |
The background color of columns and rows are white by default. You can specify background color for the entire columns/ rows by right clicking on the target row/ column and then selecting color for it.
To set background color for column/ row:
Right click on the target row/ column and select Color > [target color] from the pop-up menu. You can select a color from either Default category or Custom category.
| Select a background color |
As a result, the background color for selected row/ column is set.
| Background color is set |
You can view and specify the properties of model elements by opening their specification dialog box.
To open a model element's specification:
| Open Lane's Specification dialog box |
| The Lane Specification |
You can view a model element on Model Explorer by selecting it on chart.
To select a model element on Model Explorer:
Right click on the target model element and select Select in Tree from the pop-up menu.
| Select in Tree |
As a result, the model element is highlighted on Model Explorer.
| Model element is highlighted on Model Explorer |
When reading the chart, you may want to view the model element on its source diagram.
You can view the model element by right clicking on the target model element and selecting Show View... from the pop-up menu.
| Show the view of model element |
As a result, the view of model element is selected on the diagram.
| Model element is selected on its source diagram |
You can arrange the order of model elements with your preference.
Right click on target row/ column and select Move up or Move Down from the pop-up menu.
| Move the model element up |
| Define code type |
| Select a color for target role |
| Define a new type of chart |
| Add a code type |
| Rename the code type |
| Add a new code |
| Enter the properties of code |
| Select a code type from the combo box of Code Type |
| Chapter 4. Chart Diagram | Table of Contents | Part XIII. Report generation |
Technical Support
Sales Support
