Technical Support
Sales Support
We analyze a model element when we want to identify its related elements so as to foresee the potential impact that may cause on the model resulted by modifying the model element. The term "related" here represents any kinds of connection that can have between two elements, such as a general to-and-from relationship, a parent-child relationship, transitor, or even a sub-diagram relationship with a diagram.
By analyzing a model element, you can know its relationships with other elements. To analyze:
| Analyze a diagram element |
| NOTE: | You can analyze a model element in Model Explorer by right clicking on the desired element node in Model Explorer, and selecting Analysis... from the popup menu. |
| Create a diagram, or select an existing analysis diagram to present the result |
| Kinds of relationships that can analyze |
The result of analysis is shown in an analysis diagram.
| An analysis diagram |
The oval node at the center of diagram represents the element you have chosen to analyze, the connectors branching out are the relationships with the analyzing element and the nodes at the opposite end of connectors are the related elements.
Inside a node of a related element, you can see a tag (e.g. <<View>>), which represents the type of that related element. At the bottom part of a node box is the name of the related element.
By reading the diagram, you can identify the relationship of a model element, and determine the impact that may act upon the model when modifying the model element.
| Chapter 2. Analysis Diagram | Table of Contents | 2. Updating analyzed result |
Technical Support
Sales Support
