Technical Support
Sales Support
State machine diagram shows flow of control from state to state within single object. It usually contains simple states, composite states, composite states, transitions, events and actions.
| Create state machine diagram |
After creating a state machine diagram, an initial pseudo state appears by default. Move the mouse over it and click its resource icon Transition -> State.
| Create state from initial pseudo state |
Drag it to your preferred place and then release the mouse to confirm the place. As a result, a state is created and is connected to the initial pseudo state with a transition.
| State and transition created |
Similarly, you can use the Transition -> Final State resource to create a final state.
| Create final state |
To model substates of a composite state, you need to add one or more regions to it. To add a region, right-click the state and select Add Horizontal Region from the popup menu.
| Add region to state |
Next, you can draw the substates inside the region.
| Substates in a composite state |
To model properties of transition such as effect and guard, right-click the transition and select Open Specification... from the pop-up menu.
| Open specification of transition |
When the Transition Specification dialog box pops out, you can edit its name, effect and guard. Next, click Edit... button of the Effect property.
| Transition Specification dialog box |
In Activity Specification (Effect) dialog box, change its name, and then click OK button to apply the change.
Click OK in the Transition Specification dialog box to close it. The name and effect are shown on the transition caption.
| Name and effect shown in caption of transition |
| 1. Drawing activity diagrams | Table of Contents | 3. Drawing timing diagrams |
Technical Support
Sales Support
