Technical Support
Sales Support
A sequence diagram is used primarily to show the interactions between objects that are represented as lifelines in a sequential order.
| Create sequence diagram |
Enter name for the newly created sequence diagram in the text field of pop-up box on the top left corner.
To create actor, click Actor on the diagram toolbar and then click on the diagram.
| Create actor |
To create lifeline, you can click LifeLine on the diagram toolbar and then click on the diagram.
Alternatively, a much quicker and more efficient way is to use the resource-centric interface. Click on the Message -> LifeLine resource beside an actor/lifeline and drag.
| Create lifeline |
Move the mouse to empty space of the diagram and then release the mouse button. A new lifeline will be created and connected to the actor/lifeline with a message.
| Lifeline and message created |
When create message between lifelines/actors, activation will be automatically extended.
| Auto extending activation |
Sweeper helps you to move shapes aside to make room for new shapes or connectors. To use sweeper, click Sweeper on the diagram toolbar (under the Tools category).
| Sweeper |
Click on empty space of the diagram and drag towards top, right, bottom or left. Shapes affected will be swept to the direction you dragged.
The picture below shows the actor Inspector Assistant is being swept towards right, thus new room is made for new lifelines.
| Sweep towards right |
The picture below shows the message specify visit time is being swept downwards, thus new room is made for new messages.
| Sweep downwards |
You can also use magnet to pull shapes together. To use magnet, click Magnet on the diagram toolbar (under the Tools category).
| Magnet |
Click on empty space of the diagram and drag towards top, right, bottom or left. Shapes affected will be pulled to the direction you dragged.
The picture below shows when drag the magnet upwards, shapes below dragged position are pulled upwards.
| Pull shapes upwards using magnet |
To create combined fragment to cover messages, select the messages, right-click on the selection and select Create Combined Fragment, and then select a combined fragment type (e.g. loop) from the popup menu.
| Create combined fragment for messages |
A combined fragment of selected type will be created to cover the messages.
| Combined fragment created |
After you've created a combined fragment on the messages, you can add or remove the covered lifelines.
| Add/Remove covered lifelines |
| Check Inspector Assistant |
| The area of covered lifelines is extended |
After you've created a combined fragment on the messages, you can also add or remove operand(s).
| Manage operands |
| Remove Operand2 |
In sequence diagram, an editor appears at the bottom of diagram by default, which enables you to construct sequence diagram with the buttons there. The shortcut keys assigned to the buttons provide a way to construct diagram through keyboard. Besides constructing diagram, you can also access diagram elements listing in the editor.
| The quick editor |
There are two panes, Lifelines and Messages. The Lifelines pane enables you to create different kinds of actors and lifelines.
| Lifelines pane in quick editor |
| Buttons in Lifelines pane |
The Messages pane enables you to connect lifelines with various kinds of messages.
| Messages pane in quick editor |
| Buttons in Messages pane |
To hide the editor, click on the down arrow button that appears at the bar on top of the quick editor. To expand, click on the up arrow button.
| Collapse the quick editor |
You are able to set the way of numbering sequence messages either on diagram base or frame base.
Right click on the diagram's background, select Sequence Number and then either Single Level or Nested Level from the pop-up menu.
| Diagram-based pop-up menu |
If you choose Single Level, all sequence messages will be ordered with integers on diagram base. On the other hand, if you choose Nested Level, all sequence messages will be ordered with decimal place on diagram base.
| Single level |
Right click on the diagram's background, select Sequence Number and then either Frame-based Single Level or Frame-based Nested Level from the pop-up menu.
| Frame-based pop-up menu |
When you set the way of numbering sequence messages on frame base, the sequence messages in frame will restart numbering sequence message since they are independent and ignore the way of numbering sequence message outside the frame.
| Frame-based nested level |
| Chapter 3. Interaction Modeling | Table of Contents | 2. Drawing communication diagrams |
Technical Support
Sales Support
