Technical Support
Sales Support
Interaction overview diagram is the variant of activity diagram. Interaction overview diagrams overview control flow. The main element, frame shows any type of interaction diagram.
| Create interaction overview diagram |
To create initial node, click Initial Node on the diagram toolbar and then click on the diagram.
| Create initial node |
An initial node is created. The caption of initial node is hidden by default, to show it, right-click on the diagram and select Presentation Options > Show Shape Caption > Initial Node from the pop-up menu.
| Show caption of initial node |
To create a decision node from an initial node, move the mouse over the initial node and press its resource icon Generic Resource.
| Generic resource |
Drag it to your preferred place and then release the mouse button. Select Control Flow -> Decision Node from the pop-up menu.
| Create decision node |
If you want to show the caption of decision node, right click on the diagram background and select Presentation Options > Show Shape Caption > Decision Node from the pop-up menu.
To create an interaction use, move the mouse over a shape and press its resource icon Control Flow -> Interaction Use.
| Create interaction use |
Drag it to your preferred place and then release the mouse button. An interaction use is created and connected to the shape you selected with a control flow.
| Interaction use and control flow created |
You can make the interaction use refer to a diagram by right clicking on it and select Refers to > New Sequence Diagram from the pop-up menu.
| Make interaction use refers to diagram |
When sequence diagram is created, rename the diagram.
| Rename sequence diagram |
When you return to the interaction overview diagram, you can see the interaction use caption shows the diagram it refers to.
| Interaction use caption updated |
To create a fork node, move the moue over a shape and press its resource icon Control Flow -> Fork Node.
| Create fork node |
Drag it to your preferred place and then release the mouse button. A fork node is created and connected to the shape you selected with a control flow.
The fork node created is vertical by default. If you want to change it to horizontal, right click on the fork node and select Orientation > Horizontal from the pop-up menu.
| Change orientation of fork node |
Moreover, if you want to show the caption of fork node, right click the diagram and select Presentation Options > Show Shape Caption > Fork Node from the pop-up menu.
To create an interaction, move the mouse over a shape and press its resource icon Control Flow -> Interaction.
| Create interaction |
Drag it to your preferred place and then release the mouse button. An interaction is created and connected to the shape you selected with a control flow.
A new sequence diagram is created and associated with an interaction by default. To open it, right click on the interaction and select Associated Diagram > (target diagram name).
| Open associated diagram of interaction |
Draw the sequence diagram.
| Sequence diagram |
When you return to the interaction overview diagram, you can see the interaction shows the thumbnail of the sequence diagram.
| Updated diagram thumbnail in interaction |
To create a join node, move the mouse over a shape and press its resource icon Control Flow -> Join Node.
| Create join node |
Drag it to your preferred place and then release the mouse button. A join node is created and connected to the shape you selected with a control flow.
The join node created is vertical by default, to change it to horizontal, right-click on the join node and select Orientation > Horizontal from the pop-up menu.
Moreover, if you want to show the caption of join node, right click the diagram background and select Presentation Options > Show Shape Caption > Join Node from the pop-up menu.
To create an activity final node, move the mouse over a shape and press its resource icon Control Flow -> Activity Final Node.
| Create activity final node |
Drag it to your preferred place and then release the mouse button. An activity final node is created and connected to the shape you selected with a control flow.
| Activity final node and control flow created |
If you want to show the caption of activity final node, right click on the diagram background and select Presentation Options > Show Shape Caption > Activity Final Node from the pop-up menu.
Continue to complete the diagram.
| Completed diagram |
| 2. Drawing communication diagrams | Table of Contents | Chapter 4. Structure Modeling |
Technical Support
Sales Support
