Technical Support
Sales Support
Package diagram shows the arrangement and organization of model elements in middle to large scale project. It can show both structure and dependencies between sub-systems or modules.
| Create package diagram |
To create package, click Package on the diagram toolbar and then click on the diagram.
| Create package |
A package will be created.
| Package created |
Right click on the package and select Stereotypes > Edit Stereotypes... from the pop-up menu.
| Assign stereotypes |
When the Package Specification dialog box pops out, the Stereotypes tab is opened by default. The list on the left shows the selectable stereotypes.
If the stereotype you want to use is not on the list, click Edit Stereotypes... button.
| Edit stereotypes |
Click Add... button in the Configure Stereotypes dialog box.
| Add stereotype |
Enter name for the new stereotype (e.g. facade). Click OK button in Stereotype Specification dialog box and the Configure Stereotypes dialog box. You will see the added stereotype appears on the list in Package Specification dialog box. Select it and click Add Selected button. Next, click OK button to proceed.
| Add selected stereotypes |
Close the specification dialog box. Stereotypes will be applied to the package.
| Stereotypes assigned |
Continue to complete the diagram.
| Completed diagram |
| 2. Drawing object diagrams | Table of Contents | 4. Drawing composite structure diagrams |
Technical Support
Sales Support
