Drawing component diagrams
Component diagram shows the physical aspect of an object-oriented software system. It illustrates the architectures of the software components and dependencies between them.
Creating component diagram
  • Click on UML on toolbar and select Component Diagram from the drop down menu.
  • Right click on Component Diagram in Diagram Navigator and select New Component Diagram from the popup menu.
  • Select File > New Diagram > UML Diagrams > Component Diagram from the main menu.
Create component diagram
Creating component
To create component, click Component on the diagram toolbar and then click on the diagram.
Create component
Create component
A component will be created.
Component created
Component created
Assigning stereotypes
Right click on the package and select Stereotypes > Edit Stereotypes... from the pop-up menu.
Assign stereotypes
Assign stereotypes
When the Component Specification dialog box pops out, the Stereotypes tab is opened by default. The list on the left shows the selectable stereotypes.
If the stereotype you want to use is not on the list, click Edit Stereotypes... button.
Edit stereotypes
Edit stereotypes
Click Add... button in the Configure Stereotypes dialog box.
Add stereotype
Add stereotype
Name the stereotype (e.g. application) in the Stereotype Specification dialog box and then click OK button to close it. Click OK button in the Configure Stereotypes dialog box. The added stereotype will then be shown on the list in the Component Specification dialog box. Select it and click Add Selected button. Finally, click OK button to confirm.
Add selected stereotypes
Close the specification dialog box. Stereotypes will be applied to the package.
Stereotypes assigned
Creating provided interface
To create provided interface for a component, move the mouse over the target component and press its resource icon Realization -> Interface.
Create provided interface
Drag it to your preferred place to create a new interface, or drag to an existing interface to connect to it. Release the mouse button to create the required interface.
Provided interface created
Creating required interface
To create required interface for a component, move the mouse over the target component and press its resource icon Usage-> Interface.
Create required interface
Required interface created
Creating dependency
To create dependency, click Dependency on the diagram toolbar.
Create dependency
Create dependency
Drag from the source shape, move the mouse over the target shape and then release the mouse button to create the dependency.
Dependency created
Dependency created
Continue to complete the diagram
Completed diagram
Completed diagram
Chapter 5. Deployment Modeling Table of Contents 2. Drawing deployment diagrams
Product
Try this feature with
Visual Paradigm for UML
Technical Support
Sales Support
Discussion Forum
