Modeling and documenting test cases
Produce test case from requirement
  1. In a requirement diagram, move the mouse cursor over the requirement that we want to produce Test Case.
    Moving mouse cursor over requirement
  2. Press on the Verify <- Test Case resource of requirement and drag.
    Create test case through the resource centric interface
  3. Release the mouse button to create a test case. Name it.
    Test case is created
Creating test case and link to requirement
  1. In a requirement diagram, click the Test Case button on the diagram toolbar and then click on the diagram.
    Create Test Case
    Create Test Case
  2. Press on the Verify -> Requirement resource of test case and drag.
    Linking Requirement with Test Case
  3. Move the mouse over a requirement and then release the mouse button, a Verify relationship will be created from the test case to the requirement.
    Verify relationship created
Documenting test case
  1. Right click on a test case and select Open Specification... from the popup.
    Open specification of test case
  2. In the Test Plans tab, fill in the Steps, Procedures and Expected Results.
    Test Plan filled
    Test Plan filled
Chapter 6. Test Cases Modeling Table of Contents Part III. Enterprise Architecture
Product
Try this feature with
Visual Paradigm for UML
Technical Support
Sales Support
Discussion Forum
