Jump to Menu
Visual Paradigm 教程
我們的教程專就各類您關切題目提供詳盡的介紹和指引,讓您成為軟件開發的專家。我們會定期上載新的教程並更新現有教程,歡迎常來查來,以幫助您掌握使用 Visual Paradigm。
最受歡迎的教程
Comparing Database Schemas Visually
44,591瀏覽次數
Teach you how to use the visual database comparison utility, Visual Diff to find differences between two databases.
How to Merge Actors in Use Case Diagram?
44,172瀏覽次數
  • Removing duplicate model elements
  • Merging a duplicate master actor
Factory Method Pattern Tutorial
42,905瀏覽次數
This tutorial is aimed to guide the definition and application of factory design pattern. By reading this tutorial, you will know how to develop a model for the factory pattern, and how to apply it in practice.
How to Create Requirements Spec. in Minutes?
42,890瀏覽次數
  • Writing a Doc Base
  • Opening a Doc Base
  • Generating a Document
How to Use Stereotypes and Tagged Values?
42,850瀏覽次數
  • Create stereotypes
  • Define tag definitions
  • Set tagged values
How to Animate a UML Sequence Diagram?
42,728瀏覽次數
  • Animating sequence diagram
  • Exporting Adobe Flash from sequence diagram
Generate Hibernate Mapping for Oracle Database
42,318瀏覽次數
  • Creating object model from entity model
  • Generating ORM Source and Hibernate Mapping
Proxy Pattern Tutorial
41,514瀏覽次數
This tutorial is aimed to guide the definition and application of proxy design pattern. By reading this tutorial, you will know how to develop a model for the proxy pattern, and how to apply it itn practice.
How to Import Bizagi Project into Visual Paradigm?
41,312瀏覽次數
  • Importing .bpm file into Visual Paradigm
How to Edit an Attribute's Initial Value
40,809瀏覽次數
  • Customizing the default value of attribute in a class
  • Setting the default color of attribute in a class
Previous 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 Next
創造美好 共同成長
OK
