My Testings widget
The My Testings widget lists the opening Test Case/Test Plan/Test Case Template that are assigned to you.
Region Description
1 Symbol that indicates the priority of Testing. From most to least urgent: Red, orange, yellow, green, blue.
2 Symbol that indicates the type of Testing entry - Test Case/Test Plan/Test Case Template.
3 The name of Testing. Bold names indicate Testings that are unread. Once you have read a Testing, its name will become non-bold. You can simply click on the name of a Testing to open it.
4 Click to open the first page.
5 Click to open the previous page.
6 Click on the drop down menu and select a page to open.
7 Click to open the next page.
8 Click to open the last page.
9 Click to refresh the table contents.
10 Displays the number of Testings in current page.
11 Click on the drop down menu and select the number of maximum Testing to list in a page.
12 Click to refresh the table content.
13 Click to collapse or expand the widget.
Sort Testings
You can sort Testings by a property (e.g. name) by clicking on the corresponding column header. If you want to change the way of sorting (i.e. ascending/descending), click the header again to update the ordering.
TIPS: By sorting Testings by priority, you can realize how urgent the assigned Testings are and to decide which one to do first.
Hide a Testing temporarily (Remind Later)
When you are assigned many Testings, you may find it hard to concentrate on Testings you have to do at this moment as there are too many entries displaying in the widget. You can hide Testings that are not of your interest to make the widget lists only those important. To hide Testing temporarily, right click on the Testing you want to hide and select Remind Later from the popup menu. By applying reminder on a Testing, it will be hidden until the date and time you set.
Set a Testing to remind later
This shows the Remind Later window. You need to set the time to show the Testing in the widget again. You can set the upper option to show the Testing an hour/day/week/month later. The lower option lets you set the exact day and time of showing the Testing. By clicking on Now, the second option will be selected and the day and time would be set to current time. Click OK to confirm the setting.
Remind me next week
Remind me next week
NOTE: You can read the hidden Testings in the Remind Later widget in Home page.
Show the URL of Testing
Each Testing has a unique URL for you to visit and open in web browser. You can ask team members to follow up a Testing by sending him the URL of Testing so that he can open it, read it and take action accordingly. To check the URL of Testing, move the mouse pointer over the Testing without clicking on it. Click on the anchor icon on the right hand side.
Clicking on anchor
Clicking on anchor
You can see a popup of URL of Testing. By default the content in popup are all selected. You can copy the content directly by pressing Ctrl-C.
The popup of URL of Testing
The popup shows both the name and URL of Testing. If you want to see only the URL but not the name, uncheck with Name on the top right of popup. Note that this selection will be memorized. The next time you check for URL of Testing, the setting will be re-used.
URL show without Testing name
2. My Activities Table of Contents 4. My Issues
Technical Support
Sales Support
Discussion Forum
