Interface overview of A3 Platform Issue view
Issue is a bug, defect, complaint that require attention and action, possibly a fix or clarification of problem. Issue often comes from an Activity or Test Case, raised by tester or end user/customer. Issue view is where people report or study issues.
Issue view
Issue view
Region Description
1 Navigate to another core function of A3 Platform by pressing on a tab.
2 List/open an Issue based in different categories.
3 List/open an Activity based in different categories.
4 Select a process cell (i.e. location). The Summary page lists Issues saved to the selected process cell. Issues reported in Issue tab will automatically be saved to the selected process cell.
5 Summary tab lists Issues below. Issue tab is where you can read or report an Issue.
6
Toolbar. Here are the supported functions when Summary tab is opened:
New Issue - Click to open a blank form of Issue where you can fill in the detail of Issue and report it.
Configure Table - Press on it to set the columns, sorting of columns as well as the number of row to show per page for the table of Issues.
Show Closed - Press on it to list also Issues that have already been closed.
Select Label - Filter Issues by their labels. Only Issues marked with selected labels will be listed.
Mass Update - Press on it to set the changes you want to apply on all the Issues checked in the table of Issues, to perform a mass modification on them.
Export to PDF - Press on it to export selected Issue(s) to PDF file.
Excel - Press on it and select whether to export or import Excel of Issues.
Search - Click on it jump to the Search page to search for an Issue.
Refresh - Update the table of Issues.
<drop-down of filter> - Filter Issues base on the following categories - My Assigned / My Submitted / My Watching.
Here are the supported functions when Issue tab is opened:
Create Similar Issue - Press on it to create a new Issue base on the opening one.
Configure > Label - Press on it to create, edit or delete labels that can be set to Issues.
Configure > Type - Press on it to create, edit or delete custom attributes for Issues.
Configure > Lookup - Press on it to modify the lookup values for properties Platform, Version, Product and Component.
Edit - Press to edit the opening Issue. Unpress to exit from editing.
Print - Click on it to print the opening Issue.
Watch - Click to watch the opening Issue. Watching means to monitor the Issue. People who are watching an Issue will be notified when the Issue is being updated.
Show Link - Press to show the URL of Issue. You can browse the Issue by visiting the URL.
7 When Summary tab is selected, a list of Issues is shown here. When Issue tab is selected, this is where the form of Issue appears.
Overview of Issue view
Chapter 1. Introduction to Issue view Table of Contents Part VII. Manage users
Technical Support
Sales Support
Discussion Forum
