What is Activity Diagram?
Activity diagram is another important behavioral diagram in UML diagram to describe dynamic aspects of the system. Activity diagram is essentially an advanced version of flow chart that modeling the flow from one activity to another activity.
Activity Diagram in UML Diagram Hierarchy
Learn UML Faster, Better and Easier
Are you looking for a Free UML tool for learning UML faster, easier and quicker? Visual Paradigm Community Edition is a UML software that supports all UML diagram types. It is an international award-winning UML modeler, and yet it is easy-to-use, intuitive & completely free.
Free Download
When to Use Activity Diagram
Activity Diagrams describe how activities are coordinated to provide a service which can be at different levels of abstraction. Typically, an event needs to be achieved by some operations, particularly where the operation is intended to achieve a number of different things that require coordination, or how the events in a single use case relate to one another, in particular, use cases where activities may overlap and require coordination. It is also suitable for modeling how a collection of use cases coordinate to represent business workflows
  1. Identify candidate use cases, through the examination of business workflows
  2. Identify pre- and post-conditions (the context) for use cases
  3. Model workflows between/within use cases
  4. Model complex workflows in operations on objects
  5. Model in detail complex activities in a high level activity Diagram
Activity Diagram - Learn by Examples
A basic activity diagram - flowchart like
Basic Activity Diagram
Activity Diagram - Modeling a Word Processor
The activity diagram example below describes the workflow for a word process to create a document through the following steps:
  • Open the word processing package.
  • Create a file.
  • Save the file under a unique name within its directory.
  • Type the document.
  • If graphics are necessary, open the graphics package, create the graphics, and paste the graphics into the document.
  • If a spreadsheet is necessary, open the spreadsheet package, create the spreadsheet, and paste the spreadsheet into the document.
  • Save the file.
  • Print a hard copy of the document.
  • Exit the word processing package.
Activity Diagram Example - Word Processor
Activity Diagram Example - Process Order
Given the problem description related to the workflow for processing an order, let's model the description in visual representation using an activity diagram:
Process Order - Problem Description
Once the order is received, the activities split into two parallel sets of activities. One side fills and sends the order while the other handles the billing.
On the Fill Order side, the method of delivery is decided conditionally. Depending on the condition either the Overnight Delivery activity or the Regular Delivery activity is performed.
Finally the parallel activities combine to close the order.
The activity diagram example below visualize the flow in graphical form.
Activity Diagram - Process Order
Activity Diagram Example - Student Enrollment
This UML activity diagram example describes a process for student enrollment in a university as follows:
  • An applicant wants to enroll in the university.
  • The applicant hands a filled out copy of Enrollment Form.
  • The registrar inspects the forms.
  • The registrar determines that the forms have been filled out properly.
  • The registrar informs student to attend in university overview presentation.
  • The registrar helps the student to enroll in seminars
  • The registrar asks the student to pay for the initial tuition.
Activity Diagram - Student Enrollment
Activity Diagram - Swimlane
A swimlane is a way to group activities performed by the same actor on an activity diagram or activity diagram or to group activities in a single thread. Here is an example of a Swimlane activity diagram for modeling Staff Expenses Submission:
Activity Diagram - Use of Swimlane
Swimlane and Non-Swimlane Activity Diagram
The activity diagram example below describes the business process for meeting a new client using an activity Diagram without Swimlane.
Activity Diagram (Without Swimlane)
This figure below describes the business process for meeting a new client using an activity Diagram with Swimlane.
Activity Diagram (With Swimlane)
Activity Diagram Notation Summary
Notation Description UML Notation
Activity
Is used to represent a set of actions
Activity Diagram Notation - Activity
Action
A task to be performed
Activity Diagram Notation - Action
Control Flow
Shows the sequence of execution
Activity Diagram Notation - Control Flow
Object Flow
Show the flow of an object from one activity (or action) to another activity (or action).
Activity Diagram Notation - Object Flow
Initial Node
Portrays the beginning of a set of actions or activities
Activity Diagram Notation - Initial Node
Activity Final Node
Stop all control flows and object flows in an activity (or action)
Activity Diagram Notation - Activity Final Node
Object Node
Represent an object that is connected to a set of Object Flows
Activity Diagram Notation - Object Node
Decision Node
Represent a test condition to ensure that the control flow or object flow only goes down one path
Activity Diagram Notation - Decision Node
Merge Node
Bring back together different decision paths that were created using a decision-node.
Activity Diagram Notation - Merge Node
Fork Node
Split behavior into a set of parallel or concurrent flows of activities (or actions)
Activity Diagram Notation - Fork Node
Join Node
Bring back together a set of parallel or concurrent flows of activities (or actions).
Activity Diagram Notation - Join Node
Swimlane and Partition
A way to group activities performed by the same actor on an activity diagram or to group activities in a single thread
Activity Diagram Notation - Swimlane and Partition
Try to Draw UML Activity Diagram Now
You've learned what a Activity Diagram is and how to draw an Activity Diagram. It's time to draw an Activity Diagram of your own. Get Visual Paradigm Community Edition, a free UML software, and create your own Activity Diagram with the free Activity Diagram tool. It's easy-to-use and intuitive.
Free Download
創造美好 共同成長
