Duplicate Relationship
Written Date: September 4, 2006
User Rating: / 1 Hits: 870
Add your comment
Normally the specification of relationship contains a set of values and those values are similar when creating a new relationship. In order to reduce those user actions for setting similar values of relationship, Duplicate Relationship is introduced. With Duplicate Relationship, all values within relationship's specification, such as Stereotypes and Tagged Values, are reused.
Animated Demo
Duplicating a Relationship
The following shows the steps require to duplicate an existing relationship.
1. Right-click on a relationship. In the popup menu, select Duplicate... to open Duplicate dialog.
2. If the duplicated relationship is required to have a different name, input the new name into Name.
3. Select Source for specifying the from shape of duplicated relationship.
4. To specify the to shape of duplicated relationship, select Destination.
5. Finally, click OK to duplicate the relationship.
Before duplicate
After duplicate
Changing From or To End of a Relationship
The following shows the steps for changing the from and to end of an existing relationships. The steps involved are similar to duplicating a relationship.
1. Right-click on a relationship for showing popup menu. Then click Change From/To Shape... to open Change From/To Shape... dialog.
2. If the from shape of relationship is going to change, select the shape in Source.
3. Select the shape in Destination, when the to shape of the relationship is required to change.
4. Finally, click OK to change the relationship.
Before change
After change
• Visual Paradigm for UML Home
http://www.visual-paradigm.com/product/vpuml/
• Business Process Visual ARCHITECT
http://www.visual-paradigm.com/product/bpva/
• DB Visual ARCHITECT
http://www.visual-paradigm.com/product/dbva/
• SDE Home
http://www.visual-paradigm.com/product/sde/
• Download Free Community Edition of Visual Paradigm for UML
http://www.visual-paradigm.com/product/vpuml/vpumldownload.jsp?edition=ce
• Download Business Process Visual ARCHITECT
http://www.visual-paradigm.com/product/bpva/bpvadownload.jsp
Software Maintenance VP-UML User's Guide
Rate this Article
Click on one of the stars below to rate this article from 1 (lowest) to 5 (highest).
Comments (0)
Write comment
Rating
Comment
Enter the calculation result
security code
