Visual Paradigm桌面版 VP Online
What is Component Diagram?
UML Component diagrams are used in modeling the physical aspects of object-oriented systems that are used for visualizing, specifying, and documenting component-based systems and also for constructing executable systems through forward and reverse engineering. Component diagrams are essentially class diagrams that focus on a system's components that often used to model the static implementation view of a system.
Component Diagram Hierarchy
Learn UML Faster, Better and Easier
Are you looking for a Free UML tool for learning UML faster, easier and quicker? Visual Paradigm Community Edition is a UML software that supports all UML diagram types. It is an international award-winning UML modeler, and yet it is easy-to-use, intuitive & completely free.
Free Download
Component Diagram at a Glance
A component diagram breaks down the actual system under development into various high levels of functionality. Each component is responsible for one clear aim within the entire system and only interacts with other essential elements on a need-to-know basis.
Component Diagram at a glance
The example above shows the internal components of a larger component:
  • The data (account and inspection ID) flows into the component via the port on the right-hand side and is converted into a format the internal components can use. The interfaces on the right are known as required interfaces, which represents the services the component needed in order to carry out its duty.
  • The data then passes to and through several other components via various connections before it is output at the ports on the left. Those interfaces on the left are known as provided interface, which represents the services to deliver by the exhibiting component.
  • It is important to note that the internal components are surrounded by a large 'box' which can be the overall system itself (in which case there would not be a component symbol in the top right corner) or a subsystem or component of the overall system (in this case the 'box' is a component itself).
Basic Concepts of Component Diagram
A component represents a modular part of a system that encapsulates its contents and whose manifestation is replaceable within its environment. In UML 2, a component is drawn as a rectangle with optional compartments stacked vertically. A high-level, abstracted view of a component in UML 2 can be modeled as:
  1. A rectangle with the component's name
  2. A rectangle with the component icon
  3. A rectangle with the stereotype text and/or icon
Looks of a Component
Architect Your Modular Systems with AI
Component diagrams visualize the modular parts and physical manifestation of your system. Using Visual Paradigm’s AI Chatbot, you can instantly brainstorm system architectures, identify provided/required interfaces, and generate initial component diagrams through a simple conversational interface.
NOW AVAILABLE AI Chatbot: Your Design Partner
Simply describe your modules, microservices, or database structures to the chatbot. It will help you define:
  • Modular Boundaries: Identify which parts of your system should be encapsulated as components.
  • Dependency Mapping: Visualize how different executables and libraries interact within your release.
Learn more about our AI-driven modeling ecosystem:
AI Component Guide All AI Tools
Interface
In the example below shows two type of component interfaces:
Provided interface symbols with a complete circle at their end represent an interface that the component provides - this "lollipop" symbol is shorthand for a realization relationship of an interface classifier.
Required Interface symbols with only a half circle at their end (a.k.a. sockets) represent an interface that the component requires (in both cases, the interface's name is placed near the interface symbol itself).
Required and provided interface
Component Diagram Example - Using Interface (Order System)
Component interface example
Subsystems
The subsystem classifier is a specialized version of a component classifier. Because of this, the subsystem notation element inherits all the same rules as the component notation element. The only difference is that a subsystem notation element has the keyword of subsystem instead of component.
Component Subsystems
Port
Ports are represented using a square along the edge of the system or a component. A port is often used to help expose required and provided interfaces of a component.
Component Diagram Port
Relationships
Graphically, a component diagram is a collection of vertices and arcs and commonly contain components, interfaces and dependency, aggregation, constraint, generalization, association, and realization relationships. It may also contain notes and constraints.
Relationships Notation
Association:
  • An association specifies a semantic relationship that can occur between typed instances.
  • It has at least two ends represented by properties, each of which is connected to the type of the end. More than one end of the association may have the same type.
Component Diagram Notation: Association
Composition:
  • Composite aggregation is a strong form of aggregation that requires a part instance be included in at most one composite at a time.
  • If a composite is deleted, all of its parts are normally deleted with it.
Component Diagram Notation: Composition
Aggregation
  • A kind of association that has one of its end marked shared as kind of aggregation, meaning that it has a shared aggregation.
Component Diagram Notation: Aggregation
Constraint
  • A condition or restriction expressed in natural language text or in a machine readable language for the purpose of declaring some of the semantics of an element.
Component Diagram Notation: Constraint
Dependency
  • A dependency is a relationship that signifies that a single or a set of model elements requires other model elements for their specification or implementation.
  • This means that the complete semantics of the depending elements is either semantically or structurally dependent on the definition of the supplier element(s).
Component Diagram Notation: Dependency
Links:
  • A generalization is a taxonomic relationship between a more general classifier and a more specific classifier.
  • Each instance of the specific classifier is also an indirect instance of the general classifier.
  • Thus, the specific classifier inherits the features of the more general classifier.
Component Diagram Notation: Generalization
Modeling Source Code
  • Either by forward or reverse engineering, identify the set of source code files of interest and model them as components stereotyped as files.
  • For larger systems, use packages to show groups of source code files.
  • Consider exposing a tagged value indicating such information as the version number of the source code file, its author, and the date it was last changed. Use tools to manage the value of this tag.
  • Model the compilation dependencies among these files using dependencies. Again, use tools to help generate and manage these dependencies.
Component Example - Java Source Code
Component Diagram Java Source Code Example
Component Diagram Example - C++ Code with versioning
Component Diagram CPP code with Versioning Example
Modeling an Executable Release
  • Identify the set of components you'd like to model. Typically, this will involve some or all the components that live on one node, or the distribution of these sets of components across all the nodes in the system.
  • Consider the stereotype of each component in this set. For most systems, you'll find a small number of different kinds of components (such as executables, libraries, tables, files, and documents). You can use the UML's extensibility mechanisms to provide visual cues(clues) for these stereotypes.
  • For each component in this set, consider its relationship to its neighbors. Most often, this will involve interfaces that are exported (realized) by certain components and then imported (used) by others. If you want to expose the seams in your system, model these interfaces explicitly. If you want your model at a higher level of abstraction, elide these relationships by showing only dependencies among the components.
Component Diagram Modeling Executable Relesase
Modeling a Physical Database
  • Identify the classes in your model that represent your logical database schema.
  • Select a strategy for mapping these classes to tables. You will also want to consider the physical distribution of your databases. Your mapping strategy will be affected by the location in which you want your data to live on your deployed system.
  • To visualize, specify, construct, and document your mapping, create a component diagram that contains components stereotyped as tables.
  • Where possible, use tools to help you transform your logical design into a physical design.
Component Diagram Modeling Physical Database
Try to Draw UML Component Diagram Now
You've learned what a Component Diagram is and how to draw a Component Diagram. It's time to draw a Component Diagram of your own. Get Visual Paradigm Community Edition, a free UML software, and create your own Component Diagram with the free Component Diagram tool. It's easy-to-use and intuitive.
Free Download
创造美好 共同成长
