UML (Unified Modeling Language) Class Diagrams are the architectural blueprints of object-oriented programming. They allow you to visualize the structure of your system—the classes, their attributes, their behaviors, and how they relate to one another—before you write a single line of code.
These elements represent the "things" in your system.
name, id).calculateTotal()).+ (public), - (private), and # (protected).Relationships show how your classes interact and depend on each other.
Dog is a Animal). The sub-class inherits all attributes and methods from the parent.Interface.PlantUML allows you to write diagrams as code. Below are examples of how these relationships are structured.
@startuml
interface PaymentProcessor {
+ process(amount: float): void
abstract class Component {
+ {abstract} render(): void
class CreditCardPayment {
- cardNumber: String
PaymentProcessor <|.. CreditCardPayment : implements
Component <|-- CreditCardPayment : inherits
@enduml
@startuml
class Library {
+ name: String
class Book {
+ title: String
class House {
+ address: String
class Room {
+ size: int
Library o-- Book : Aggregation (Weak)
House *-- Room : Composition (Strong)
@enduml
Looking for a powerful, free diagram-as-code tool? Effortlessly render PlantUML, Mermaid, Graphviz, and 20+ programming languages in real time—powered by instant AI error fixing and automatic format detection.
To master UML class diagrams, the best approach is to see how various components interact within a single, cohesive system. Below is a comprehensive example representing a Library Management System.
This system demonstrates the core building blocks: Classes with various visibility levels, Interfaces, Abstract Classes, and the most common Relationships (Inheritance, Realization, Aggregation, and Composition).
You can copy this block into any PlantUML editor to render the diagram.
Code snippet
@startuml
' --- Packages ---
package "Core System" {
' --- Abstract Class & Interface ---
interface Loanable {
+ isAvailable(): boolean
abstract class LibraryItem {
# title: String
# ISBN: String
+ {abstract} getDetails(): String
' --- Concrete Classes ---
class Book {
- author: String
+ getDetails(): String
class Member {
- name: String
- memberId: String
+ borrow(item: LibraryItem): void
class Library {
- name: String
' --- Relationships ---
' Inheritance
LibraryItem <|-- Book
' Implementation
Loanable <|.. Book
' Composition: A Library owns Rooms; if Library is gone, Rooms cease to exist
Library *-- "many" Room
' Aggregation: A Library has Members; if Library is gone, Members still exist
Library o-- "many" Member
' Association
Member --> LibraryItem : borrows
@enduml
By analyzing the code above, you can see how the syntax covers the requirements of the cheat sheet:
Defining Elements:
interface and abstract class: Used to define contracts and base templates for Book.
Visibility Modifiers: Notice the use of - (private), # (protected), and + (public) inside the classes to define how data is accessed.
Defining Relationships:
Inheritance (<|--): Used because a Book is a LibraryItem.
Realization (<|..): Used because Book implements the Loanable interface.
Composition (*--): The library strictly owns the rooms (they cannot exist outside the library).
Aggregation (o--): Members are associated with the library but exist independently of it.
One-way Association (-->): A Member knows about the LibraryItem they are borrowing, but the item does not necessarily need to know about the member.
Using this combined view allows you to see the "big picture" of your software architecture. Instead of viewing classes in isolation, this layout helps you understand how memory might be managed (Composition vs. Aggregation) and how your code should be organized into modules (Packages).
Are you ready to try mapping out your own project, or would you like to refine the components of this library example further?
