Comprehensive Guide: Identifying Use Cases in Use Case Modeling
📘 Introduction
In software development, use cases serve as the vital bridge between stakeholder needs and system behavior. They capture what a system must do to deliver measurable value, deliberately avoiding premature technical or design decisions. Yet, the most critical—and often mishandled—phase of use case modeling is simply identifying the right use cases in the first place. When done poorly, teams end up with bloated requirement lists, misaligned features, and systems that miss the mark. When done well, use cases become a shared, actionable language that aligns users, developers, and business stakeholders around clear goals.
This guide provides a practical, step-by-step framework for identifying high-quality use cases. Drawing on established methodologies such as Constantine and Lockwood’s essential use case approach, Schneider and Winters’ user-centric modeling principles, and Agile Modeling (AM/AMDD) practices, you will learn how to elicit behaviors from stakeholders, validate candidates against core cohesion and value criteria, model them effectively, and iteratively refine them as your project evolves. Whether you are a business analyst, product owner, system architect, or developer, this guide equips you with the techniques, validation checklists, and mindset needed to build use case models that are lean, stakeholder-aligned, and firmly rooted in real-world needs.
Use case modeling is a foundational practice for capturing behavioral requirements from the user’s perspective. Unlike functional specifications or technical designs, use cases describe what a system must do to deliver measurable value to its actors. This guide synthesizes established practices (Constantine & Lockwood, Schneider & Winters, Agile Modeling/AMDD principles) into a structured, actionable process for identifying use cases effectively.
🔹 Phase 1: Establish the Foundation
1. Adopt a User-Centric Mindset
  • Model from the user’s point of view, not the developer’s. Your goal is to capture how users will interact with the system to fulfill real-world needs.
  • Avoid technical assumptions, UI layouts, or implementation details at this stage. Focus on essential behavior.
2. Identify Actors First
  • Start by listing all roles (not individuals) that will interact with the system:
    • Primary actors: Those who initiate actions to achieve a goal (e.g., Student, Professor, Registrar).
    • Secondary actors: External systems or roles that support or are invoked by the system (e.g., Payment Gateway, Notification Service).
  • Note: An “actors-first” approach is highly effective, though you may also start with a single actor and expand outward. Both are valid; stay flexible.
🔹 Phase 2: Elicit Behavioral Requirements
Use two complementary techniques to uncover potential use cases. You may apply one, the other, or both.
Technique A: Stakeholder Questioning (Essential Use Case Approach)
Ask stakeholders the following questions from each actor’s perspective:
Question Purpose
What are users in this role trying to accomplish? Identify core goals
What do users need to be able to do to fulfill this role? Surface required capabilities
What are the main tasks of users in this role? Reveal recurring workflows
What information do users need to examine, create, or change? Highlight data interactions
What do users need to be informed of by the system? Capture system-to-user communications
What do users need to inform the system about? Capture user-to-system inputs
Example (Student Actor):
  • Enroll in, drop, pass, or fail seminars
  • View available seminars & prerequisites
  • Obtain transcripts, schedules, fee statements
  • Pay fees, receive loans/grants, process reimbursements
  • Receive notifications about room/time changes or cancellations
  • Provide/update personal contact information
Technique B: Usage Scenario Brainstorming
  • Facilitate workshops where stakeholders describe real-world situations the system should (or should not) support.
  • Focus on behavioral outcomes, not technical constraints.
  • Examples:
    • A student tries to enroll in a seminar but lacks prerequisites.
    • A professor requests a seminar list for all courses they teach.
    • A student wants to drop a seminar the day after the official drop deadline.
    • A researcher applies for a grant and receives only partial funding.
💡 Tip: Combine both techniques. Questions ensure completeness; scenarios ground requirements in reality.
🔹 Phase 3: Synthesize & Validate Use Cases
Group elicited behaviors into preliminary use cases, then validate them against core quality criteria.
✅ Validation Checklist
Criterion Description How to Apply
Functional Cohesion One use case = one cohesive service that delivers clear value Split Enroll in Seminar and Drop Seminar into separate use cases
Temporal Cohesion Steps occur within a contiguous time period without long pauses or restarts Avoid bundling Enroll → Attend → Pass into one use case; the waiting periods break temporal cohesion
Business Value Must provide measurable value to at least one actor If it doesn’t deliver value, it’s likely a step inside a use case, not a use case itself
Actor-Use Case Mapping Every actor ↔ at least one use case; every use case ↔ at least one actor Remove orphaned actors or valueless use cases
Repetition Handling Multiple invocations are normal A student enrolling in 5 seminars doesn’t require 5 use cases; one Enroll in Seminar invoked multiple times suffices
📌 Remember: Use cases are not system functions. A need like “available seminar list” may be a function, but in use case modeling, it’s often just a reference or data element within a larger use case (e.g., Browse Seminars).
🔹 Phase 4: Model & Diagram (Use Case Diagrams)
Use case diagrams provide a high-level overview. The real depth lives in the written use case specifications.
Diagramming Guidelines
  1. Keep diagrams small & simple → Favor multiple focused diagrams over one massive view.
  2. Draw associations between actors and use cases → Omit arrowheads to prevent confusion with data flow.
  3. System boundary box is optional → Include only if you need to explicitly mark out-of-scope use cases.
  4. Do not model time or sequence → Use case diagrams show capabilities, not order. Use UML State Machine or Activity diagrams for lifecycle/flow.
  5. Use a subset of UML notation → Essential modeling strips away non-essential syntax to keep focus on behavior.
  6. Expect evolution → Models are living artifacts. Refactor, merge, split, or discard use cases as understanding deepens.
📝 Naming Convention: Use Verb + Noun format (e.g., Enroll in Seminar, Record Student Marks). Consistency is helpful, but agile modeling embraces “just barely good enough” → prioritize clarity over perfection in early drafts.
🔹 Agile & Practical Best Practices
Practice Why It Matters
Breadth-first approach Paint a wide picture first to understand scope, then dive into details iteratively.
Model with others Collaborate with stakeholders, domain experts, and developers. Flexibility > rigid process.
Requirements-first mindset No requirements = nothing to build. Software must solve real stakeholder needs.
Essential over concrete Delay technological decisions. Record Student Marks could be web-based, form-based, or API-driven → the use case remains valid regardless.
Incremental refinement Initial use cases are preliminary. Expect to refactor as you learn more.
⚠️ Common Pitfalls to Avoid
Pitfall Consequence Solution
Confusing use cases with functions/features Overly granular or technical models Validate against “measurable value to actor”
Adding UI/tech details prematurely Locks design too early Stick to essential, technology-agnostic behavior
Trying to show sequence/time in diagrams Clutters diagrams, misuses UML Move ordering logic to state/activity diagrams
Building massive, monolithic diagrams Hard to read, maintain, or discuss Split by actor, domain, or release scope
Perfectionism in early drafts Slows progress, discourages iteration Embrace “good enough” → refine later
🧭 Quick Reference: Use Case Identification Workflow
  1. List actors (roles, not people)
  2. Ask the 6 essential questions per actor
  3. Brainstorm usage scenarios with stakeholders
  4. Cluster behaviors into candidate use cases
  5. Validate against functional/temporal cohesion, business value, and actor mapping
  6. Sketch lightweight use case diagrams (no arrows, small scope, essential focus)
  7. Iterate → refactor, split, merge, or retire use cases as the project evolves
  8. Document → expand validated use cases into detailed specifications for development
💡 Final Thoughts
Identifying use cases is not a one-time documentation exercise. It’s a collaborative, iterative discovery process that aligns system capabilities with real user goals. By starting broad, validating against cohesion and value, keeping diagrams lean, and embracing evolutionary refinement, you ensure that your use cases remain actionable, stakeholder-aligned, and development-ready.
“If there are no requirements, then you are done because you have nothing to build.”
Focus on behavior, deliver value, and let the model evolve with your project.
For next steps: Once use cases are identified, transition to writing detailed use case specifications (basic flow, alternate flows, exceptions, pre/post-conditions) and link them to traceable requirements and test cases.
