Comprehensive Guide: Use Cases → Class Diagram → ERD
Introduction
This guide walks you through the systematic transformation from requirements (Use Cases) to object-oriented design (Class Diagrams) to database design (ERDs). Understanding this progression is crucial for building robust, well-structured applications.
The Progression Flow
ERD Modeling: Use Cases → Class Diagram → ERD Workflow
Phase 1: Use Case Analysis
Key Concepts
Use Case: A description of how a user interacts with a system to achieve a goal.
Components:
  • Actor: User or external system interacting with the system
  • Use Case: Specific functionality or feature
  • Relationship: Include, Extend, Generalization
Step-by-Step Process
Step 1: Identify Actors
  • Who uses the system?
  • What are their roles?
  • List all user types and external systems
Step 2: Identify Use Cases
  • What functions does the system provide?
  • What are the user goals?
  • Group related functionalities
Step 3: Define Relationships
  • Include: Mandatory sub-function (e.g., "Login" included in "Place Order")
  • Extend: Optional behavior (e.g., "Apply Discount" extends "Checkout")
  • Generalization: Parent-child relationship between use cases
Step 4: Write Descriptions
For each use case, document:
  • Primary actor
  • Preconditions
  • Postconditions
  • Main flow (happy path)
  • Alternative flows
PlantUML Example: Library Management System
@startuml Library System Use Cases
left to right direction
actor "Librarian" as Librarian
actor "Member" as Member
actor "System Admin" as Admin
rectangle "Library Management System" {
  usecase "Browse Books" as UC1
  usecase "Search Books" as UC2
  usecase "Borrow Book" as UC3
  usecase "Return Book" as UC4
  usecase "Reserve Book" as UC5
  usecase "Manage Members" as UC6
  usecase "Manage Books" as UC7
  usecase "Login" as UC8
  UC2 --|> UC1 : extends
  Member --> UC1
  Member --> UC2
  Member --> UC3
  Member --> UC4
  Member --> UC5
  Member --> UC8
  Librarian --> UC3
  Librarian --> UC4
  Librarian --> UC6
  Librarian --> UC7
  Librarian --> UC8
  Admin --> UC6
  Admin --> UC7
  Admin --> UC8
  UC8 <|-- UC3 : <<include>>
  UC8 <|-- UC4 : <<include>>
  UC8 <|-- UC6 : <<include>>
@enduml
Tips for Use Case Development
  1. Keep it simple: Use cases should be understandable to non-technical stakeholders
  2. Focus on user goals: Write from the user's perspective
  3. Avoid implementation details: Don't include technical constraints
  4. Prioritize: Identify core vs. supporting use cases
  5. Validate: Ensure each use case provides value to the user
Phase 2: Class Diagram Design
Key Concepts
Class: Blueprint for objects with attributes and methods
Components:
  • Attributes: Properties/fields (e.g., name, price)
  • Methods: Behaviors/functions (e.g., calculateTotal())
  • Relationships: Association, Aggregation, Composition, Inheritance
Step 1: Extract Candidate Classes from Use Cases
  • Look for nouns in use case descriptions
  • Identify "thing" concepts (Book, Member, Transaction)
  • Group related concepts
Step 2: Define Class Responsibilities
  • What data does each class hold?
  • What operations does each class perform?
  • Apply Single Responsibility Principle
Step 3: Establish Relationships
Relationship Type Description Example
Association Uses General connection between classes Student → Course
Aggregation Has-a Part-whole relationship (weak) Department → Employees
Composition Has-a Strong part-whole (lifecycle dependent) Order → OrderLineItem
Inheritance Is-a Parent-child relationship Book → EBook
Step 4: Define Multiplicity
  • Specify how many instances participate in a relationship
  • 1, 0..1, 0.., 1.., etc.
Step 5: Add Methods
  • Identify operations from use cases
  • Assign methods to appropriate classes
PlantUML Example: Library Management System Classes
@startuml Library Class Diagram
class Book {
  -id: String
  -title: String
  -author: String
  -isbn: String
  -year: int
  -copiesAvailable: int
  +getStatus(): String
  +updateCopies(quantity: int): void
class Member {
  -id: String
  -name: String
  -email: String
  -phone: String
  -membershipDate: Date
  +borrowBook(book: Book): boolean
  +returnBook(book: Book): void
  +reserveBook(book: Book): boolean
  +getBorrowingHistory(): List<Transaction>
class BorrowingTransaction {
  -id: String
  -borrowedDate: Date
  -dueDate: Date
  -returnedDate: Date
  -status: String
  +calculateFine(): double
  +renew(): boolean
class Fine {
  -id: String
  -amount: double
  -paid: boolean
  +pay(): void
class Reservation {
  -id: String
  -reservedDate: Date
  -status: String
  +cancel(): void
class Librarian {
  -id: String
  -name: String
  -employeeId: String
  +processBorrow(member: Member, book: Book): void
  +processReturn(transaction: BorrowingTransaction): void
class SystemAdmin {
  -id: String
  -name: String
  +generateReport(): void
  +manageSystem(): void
Member "1" -- "0..*" BorrowingTransaction : makes
BorrowingTransaction "1" -- "1" Book : involves
Member "1" -- "0..*" Reservation : places
Reservation "1" -- "1" Book : for
BorrowingTransaction "1" -- "0..1" Fine : may result in
Librarian --|> Member : extends
SystemAdmin --|> Member : extends
@enduml
Tips for Class Diagram Design
  1. Start with nouns: Use cases → nouns → candidate classes
  2. Validate with CRUD: Every class should support Create, Read, Update, Delete
  3. Avoid over-engineering: Don't create classes for everything
  4. Use design patterns: When applicable (e.g., Factory, Observer)
  5. Consider future changes: Design for extensibility
Phase 3: ERD Design
Key Concepts
Entity: Real-world object or concept (becomes table)
Components:
  • Entities (Tables)
  • Attributes (Columns)
  • Relationships (Foreign Keys)
  • Primary Keys (Unique identifiers)
  • Foreign Keys (Pointers to other tables)
Step 1: Map Classes to Entities
  • Each class typically becomes a table
  • Attributes become columns
  • Identify primary key for each entity
Step 2: Handle Relationships
  • One-to-One: Choose one side as parent
  • One-to-Many: Add foreign key on "many" side
  • Many-to-Many: Create junction table
Step 3: Normalize
  • 1NF: Eliminate repeating groups
  • 2NF: Remove partial dependencies
  • 3NF: Remove transitive dependencies
Step 4: Define Constraints
  • Primary key constraints
  • Foreign key constraints
  • Unique constraints
  • Check constraints
  • Default values
Step 5: Consider Performance
  • Add indexes on frequently queried columns
  • Denormalize where necessary for performance
PlantUML Example: Library System ERD
@startuml Library ERD
entity "Book" as book {
  * id : VARCHAR(20) <<PK>>
  * title : VARCHAR(255)
  * author : VARCHAR(100)
  * isbn : VARCHAR(17)
  year : INTEGER
  copies_available : INTEGER
entity "Member" as member {
  * name : VARCHAR(100)
  * email : VARCHAR(100)
  phone : VARCHAR(15)
  membership_date : DATE
entity "Borrowing_Transaction" as transaction {
  * member_id : VARCHAR(20) <<FK>>
  * book_id : VARCHAR(20) <<FK>>
  borrowed_date : DATETIME
  due_date : DATETIME
  returned_date : DATETIME
  status : VARCHAR(20)
entity "Reservation" as reservation {
  reserved_date : DATETIME
entity "Fine" as fine {
  * transaction_id : VARCHAR(20) <<FK>>
  amount : DECIMAL(10,2)
  paid : BOOLEAN
  paid_date : DATE
entity "Librarian" as librarian {
  employee_id : VARCHAR(20)
entity "System_Admin" as admin {
entity "Book_Author" as book_author {
  * author_name : VARCHAR(100)
member ||--o{ transaction : "makes"
transaction }o--|| book : "involves"
member ||--o{ reservation : "places"
reservation }o--|| book : "for"
transaction ||--o| fine : "may result in"
librarian }|--|| member : "extends"
admin }|--|| member : "extends"
book ||--o{ book_author : "has"
book_author }o--|| book : "belongs to"
@enduml
Advanced ERD Tips
Handling Inheritance
Options for mapping inheritance in ERD:
  1. Single Table: All classes in one table (with type discriminator)
  2. Class Table: One table per class (with foreign keys)
  3. Concrete Table: One table per concrete class
Many-to-Many with Attributes
When a relationship has attributes, make it an entity:
entity "Student" {
  * id : PK
entity "Course" {
  * id : PK
  title : VARCHAR
entity "Enrollment" {
  * student_id : FK
  * course_id : FK
  enrollment_date : DATE
  grade : VARCHAR
Student ||--o{ Enrollment : "enrolls in"
Course ||--o{ Enrollment : "has"
Mapping Relationships
How Relationships Translate
UML Relationship ERD Relationship Implementation
Association (1..*) One-to-Many Foreign key in child
Association (..) Many-to-Many Junction table
Association (1..1) One-to-One Foreign key on either side
Aggregation One-to-Many Foreign key with nullable parent
Composition One-to-Many with cascade Foreign key with ON DELETE CASCADE
Inheritance Varied See below
Inheritance Mapping Example
' Single Table Strategy
entity "Payment" {
  * id : PK
  amount : DECIMAL
  status : VARCHAR
  type_discriminator : VARCHAR
  card_number : VARCHAR  (nullable)
  account_number : VARCHAR  (nullable)
  bank_code : VARCHAR  (nullable)
  expiry_date : DATE  (nullable)
' Class Table Strategy
entity "Payment" {
  * id : PK
  amount : DECIMAL
  status : VARCHAR
entity "CreditCardPayment" {
  * payment_id : FK
  expiry_date : DATE
entity "BankTransferPayment" {
  * payment_id : FK
  bank_code : VARCHAR
' Concrete Table Strategy
  * id : PK
  amount : DECIMAL
  status : VARCHAR
  expiry_date : DATE
  * id : PK
  amount : DECIMAL
  status : VARCHAR
  bank_code : VARCHAR
Best Practices & Tips
From Use Cases to Classes
✅ DO:
  • Extract nouns from use case descriptions
  • Group related data and behavior
  • Consider system boundaries
❌ DON'T:
  • Create classes for every noun
  • Ignore behavior (methods)
  • Overlook relationships
From Classes to ERD
✅ DO:
  • Each persistent class → table
  • Each attribute → column
  • Consider performance (indexes, denormalization)
❌ DON'T:
  • Map transient/derived fields (calculate instead)
  • Forget to handle inheritance
  • Ignore data integrity constraints
General Guidelines
  1. Start with High-Level Use Cases
    • Focus on main system functionality
    • Prioritize core features
  2. Iterate and Refine
    • Design → Review → Refine → Repeat
    • Get stakeholder feedback
  3. Use Naming Conventions
    • Classes: PascalCase (e.g., BorrowingTransaction)
    • Attributes: camelCase (e.g., borrowedDate)
    • Tables: snake_case (e.g., borrowing_transaction)
    • Columns: snake_case (e.g., borrowed_date)
  4. Consider Different Perspectives
    • Business domain (use cases)
    • Object orientation (class diagrams)
    • Data persistence (ERD)
  5. Maintain Consistency
    • Traceability: Each use case → classes → tables
    • Keep documentation in sync
Common Pitfalls to Avoid
Pitfall Solution
Overcomplicating use cases Keep them high-level and user-focused
Missing relationships Review associations carefully
Forgetting navigation Consider both directions of relationships
Inconsistent naming Adopt and follow a naming convention
Ignoring performance Add indexes, consider denormalization
Not handling edge cases Include alternative flows in use cases
Complete Example: E-Commerce System
1. Use Case Diagram
@startuml E-Commerce Use Cases
actor "Customer" as Customer
actor "Admin" as Admin
actor "Payment Gateway" as PaymentGateway
rectangle "E-Commerce System" {
  usecase "Browse Products" as UC1
  usecase "Search Products" as UC2
  usecase "Add to Cart" as UC3
  usecase "View Cart" as UC4
  usecase "Checkout" as UC5
  usecase "Process Payment" as UC6
  usecase "View Order History" as UC7
  usecase "Manage Products" as UC8
  usecase "Manage Orders" as UC9
  usecase "Login" as UC10
  usecase "Register" as UC11
  usecase "Apply Coupon" as UC12
  Customer --> UC1
  Customer --> UC2
  Customer --> UC3
  Customer --> UC4
  Customer --> UC5
  Customer --> UC7
  Customer --> UC10
  Customer --> UC11
  Admin --> UC8
  Admin --> UC9
  Admin --> UC10
  PaymentGateway --> UC6
  UC10 <|-- UC5 : <<include>>
  UC10 <|-- UC8 : <<include>>
  UC10 <|-- UC9 : <<include>>
  UC5 <|-- UC12 : <<extend>>
@enduml
2. Class Diagram
@startuml E-Commerce Classes
class User {
  -id: String
  -username: String
  -password: String
  -email: String
  -firstName: String
  -lastName: String
  -createdAt: Date
  +login(): boolean
  +logout(): void
  +updateProfile(): void
class Customer {
  -phone: String
  -address: String
  +getOrderHistory(): List<Order>
  +addToCart(product: Product, quantity: int): void
  +checkout(): Order
class Admin {
  -role: String
  +manageProducts(): void
  +manageOrders(): void
class Product {
  -id: String
  -name: String
  -description: String
  -price: double
  -stockQuantity: int
  -category: String
  +updateStock(quantity: int): void
  +getRating(): double
class Category {
  -id: String
  -name: String
  +getProducts(): List<Product>
class Cart {
  -id: String
  -createdDate: Date
  -status: String
  +addItem(product: Product, quantity: int): void
  +removeItem(product: Product): void
  +updateQuantity(product: Product, quantity: int): void
  +calculateTotal(): double
class CartItem {
  -id: String
  -quantity: int
  -unitPrice: double
  +getSubtotal(): double
class Order {
  -id: String
  -orderDate: Date
  -status: String
  -totalAmount: double
  -shippingAddress: String
  +updateStatus(status: String): void
  +cancel(): void
class OrderItem {
  -id: String
  -quantity: int
  -unitPrice: double
  -discount: double
class Payment {
  -id: String
  -amount: double
  -paymentDate: Date
  -status: String
  -transactionId: String
  +process(): boolean
  +refund(): boolean
class Coupon {
  -code: String
  -discountType: String
  -discountValue: double
  -validFrom: Date
  -validTo: Date
  +isValid(): boolean
  +apply(amount: double): double
class Review {
  -id: String
  -rating: int
  -comment: String
  -createdAt: Date
User --|> Customer
User --|> Admin
Customer "1" -- "1" Cart : has
Cart "1" -- "0..*" CartItem : contains
CartItem "1" -- "1" Product : references
Product "0..*" -- "1" Category : belongs to
Customer "1" -- "0..*" Order : places
Order "1" -- "0..*" OrderItem : contains
OrderItem "1" -- "1" Product : references
Order "1" -- "1" Payment : has
Customer "1" -- "0..*" Review : writes
Product "1" -- "0..*" Review : receives
Order "1" -- "0..1" Coupon : uses
@enduml
3. ERD
@startuml E-Commerce ERD
entity "users" as user {
  * id : VARCHAR(36) <<PK>>
  * username : VARCHAR(50) [unique]
  * email : VARCHAR(100) [unique]
  password_hash : VARCHAR(255)
  first_name : VARCHAR(50)
  last_name : VARCHAR(50)
  user_type : VARCHAR(20)
  phone : VARCHAR(20)
  address : TEXT
  created_at : TIMESTAMP
entity "products" as product {
  * name : VARCHAR(200)
  description : TEXT
  price : DECIMAL(10,2)
  stock_quantity : INTEGER
  category_id : VARCHAR(36) <<FK>>
  updated_at : TIMESTAMP
entity "categories" as category {
  description : TEXT
  parent_category_id : VARCHAR(36) <<FK>>
entity "carts" as cart {
  user_id : VARCHAR(36) <<FK>>
  created_date : TIMESTAMP
entity "cart_items" as cart_item {
  * cart_id : VARCHAR(36) <<FK>>
  * product_id : VARCHAR(36) <<FK>>
  quantity : INTEGER
  unit_price : DECIMAL(10,2)
entity "orders" as order {
  order_date : TIMESTAMP
  total_amount : DECIMAL(10,2)
  shipping_address : TEXT
  coupon_code : VARCHAR(50) <<FK>>
entity "order_items" as order_item {
  * order_id : VARCHAR(36) <<FK>>
  quantity : INTEGER
  discount : DECIMAL(10,2)
entity "payments" as payment {
  payment_date : TIMESTAMP
  transaction_id : VARCHAR(100)
  payment_method : VARCHAR(50)
entity "coupons" as coupon {
  * code : VARCHAR(50) <<PK>>
  discount_type : VARCHAR(20)
  discount_value : DECIMAL(10,2)
  valid_from : DATE
  valid_to : DATE
  usage_limit : INTEGER
  used_count : INTEGER
entity "reviews" as review {
  rating : INTEGER
  comment : TEXT
user ||--o| cart : "has"
user ||--o{ order : "places"
user ||--o{ review : "writes"
category ||--o{ product : "contains"
cart ||--o{ cart_item : "contains"
cart_item }o--|| product : "references"
order ||--o{ order_item : "contains"
order_item }o--|| product : "references"
order ||--o| payment : "has"
order }o--o| coupon : "uses"
product ||--o{ review : "receives"
@enduml
Successfully transforming Use Cases → Class Diagrams → ERDs requires:
  1. Understanding the purpose of each diagram type
  2. Systematic extraction of concepts at each stage
  3. Maintaining traceability between models
  4. Considering multiple perspectives (business, object-oriented, data)
  5. Following best practices and avoiding common pitfalls
The examples provided demonstrate how to apply these concepts to real-world scenarios. Remember that software development is iterative—your models will evolve as you gain deeper understanding of requirements and constraints.
Quick Reference: Key Takeaways
Phase Focus Primary Output Key Technique
Use Cases Requirements Functional requirements Identify actors and goals
Class Diagrams Object Design Object structure Extract classes and relationships
ERDs Database Design Data storage model Map classes to entities
Remember: These models work together to create a complete picture of your system—from user requirements to database implementation.
