UML communication diagrams, like the sequence diagrams - a kind of interaction diagram, shows how objects interact. A communication diagram is an extension of object diagram that shows the objects along with the messages that travel from one to another. In addition to the associations among objects, communication diagram shows the messages the objects send each other.
Are you looking for a Free UML tool for learning UML faster, easier and quicker? Visual Paradigm Community Edition is a UML software that supports all UML diagram types. It is an international award-winning UML modeler, and yet it is easy-to-use, intuitive & completely free.
Free DownloadIn the example of the notation for a communication diagram, objects (actors in use cases) are represented by rectangles. In the example (generic communication diagram):
The communication diagram and the sequence diagram are similar. They're semantically equivalent, that is, the present the same information, and you can turn a communication to a sequence diagram and vice versa. The main distinction between them is that the communication diagram arranged elements according to space, the sequence diagram is according to time.
Of the two types of interaction diagrams, sequence diagrams seem to be used far more than communication diagrams. So, why would you use communication diagrams? First of all, they are very useful for visualizing the relationship between objects collaborating to perform a particular task. This is difficult to determine from a sequence diagram. In addition, communication diagrams can also help you determine the accuracy of your static model (i.e., class diagrams).
If you open this sequence diagram in Visual Paradigm you can automatically generate the communication diagram shown in figure below:
Note: If you compare the two diagrams, you'll see they both contain objects and messages. It also becomes clear that it's much easier to determine the time ordering of messages by looking at the sequence diagram and it's easier to see the relationships between objects by looking at the communication diagram.
Objects participating in a collaboration come in two flavors: supplier and client.
Links
Messages in communication diagrams are shown as arrows pointing from the Client object to the Supplier object. Typically, messages represent a client invoking an operation on a supplier object. They can be modeled along with the objects in the following manner:
For example, in the communication diagram in the figure below, you can follow the sequence numbers to determine the order of messages between objects:
For example:
Based on the example above, the "CalAmtCanBorrow" message is the first nested message under "EnquireBorrower" and is given the sequence number 1.1. The second nested message under "EnquireBorrower" is "DisplayInvalidMsg", so it's given a sequence number of 1.2.
Note that:
You've learned what a Communication Diagram is and how to draw a Communication Diagram. It's time to draw a Communication Diagram of your own. Get Visual Paradigm Community Edition, a free UML software, and create your own Communication Diagram with the free Communication Diagram tool. It's easy-to-use and intuitive.
Free Download
