A Beginner’s Guide to Enterprise Architecture Building Blocks
Introduction
In Enterprise Architecture, complex systems are not built from scratch in one monolithic step. Instead, they are assembled from standardized, reusable components known as Building Blocks. Think of them as the architectural “Lego bricks” of an organization: each block provides a specific piece of functionality, and when combined according to a clear design, they form a complete, interoperable enterprise system.
This guide provides a complete, self-contained overview of building blocks, their types, how they evolve during architecture development, and how they are applied in real-world scenarios.
What is a Building Block?
Building Block is a package of functionality defined to meet specific business needs across an organization. It is not just a piece of software; it represents a clearly defined capability that can be combined with other blocks to deliver complete architectures and solutions.
Every building block has published interfaces, which are the standardized ways other systems or users interact with it. Because interfaces are public and stable, different blocks can interoperate seamlessly, even if they are built by different teams or vendors.
Core Principles of Architecture Composition
An enterprise architecture is essentially a composition of:
  1. A set of building blocks depicted in an architectural model.
  2. A specification of how those blocks are connected to meet overall system requirements.
When designing with building blocks, three guiding principles apply:
  • Relevance: Only include blocks that implement services the enterprise actually requires.
  • Flexibility: A single block may implement one, several, or only part of a required service.
  • Standards Compliance: All building blocks should conform to organizational or industry standards.
Characteristics of a Good Building Block
Not every component qualifies as a well-designed building block. To be effective in enterprise architecture, a building block should possess the following characteristics:
  • Considers Implementation & Usage: Designed with real-world deployment in mind, and evolves to leverage new technologies and standards.
  • Modular & Composable: Can be assembled from smaller blocks or act as a subassembly within larger blocks.
  • Reusable & Replaceable: Designed to be deployed across multiple projects without rewriting, and easily swapped out if a better option emerges.
  • Loosely Coupled Specification: The what (specification) is kept separate from the how (implementation). This allows the same functionality to be realized in multiple ways without breaking the architecture.
  • Well-Specified with Stable Interfaces: Clear, documented boundaries and interaction points that do not change frequently.
The Two Core Types: ABBs vs. SBBs
Building blocks operate at different levels of abstraction. The TOGAF framework distinguishes between two primary types:
1. Architecture Building Blocks (ABBs)
  • Focus: What needs to be done.
  • Nature: Abstract, functional, and requirement-driven. They represent architecture documentation, models, and high-level capabilities.
  • When Defined: Primarily during Phases A, B, C, and D of the architecture development cycle.
  • Minimum Specification Includes:
    • Fundamental functionality and attributes (semantics, security, manageability)
    • Supplied interfaces
    • Interoperability and relationships to other blocks
    • Dependent blocks with required functionality
    • Mapping to business/organizational entities and policies
  • Role: Capture business, data, application, and technology requirements. They guide and shape the selection of concrete products.
2. Solution Building Blocks (SBBs)
  • Focus: How it will be implemented.
  • Nature: Concrete, implementation-specific, and product/vendor-aware. They represent real software, hardware, or custom developments.
  • When Defined: First appear in Phase E, where product-specific options are evaluated to fill architectural gaps.
    • Specific functionality and attributes
    • Implemented interfaces
    • Required SBBs and their interface names
    • Mapping to IT topology and operational policies
    • Shared attributes (security, scalability, performance, configurability)
    • Design drivers, constraints, and relationships back to ABBs
  • Role: Define the actual products and components that will deliver the functionality.
Aspect Architecture Building Block (ABB) Solution Building Block (SBB)
Question Answered What capability is required? Which product/component delivers it?
Abstraction Level High/Logical Low/Physical
Vendor Awareness Vendor-neutral Product/Vendor-specific
Primary Phase A, B, C, D E onwards
Output Requirements & Functional Models Procurement, Development, Deployment
How Building Blocks Evolve Through the ADM Cycle
The Architecture Development Method (ADM) is an iterative process where building blocks mature from abstract concepts to deployed solutions:
  1. Phase A (Architecture Vision): Building blocks start as high-level, abstract entities. They outline the core capabilities needed to achieve the vision.
  2. Phases B, C, D (Business, Data, Application, Technology): Blocks are refined within their respective domains. Functional definitions are expanded, interfaces are clarified, and relationships between blocks are mapped.
  3. Phase E (Opportunities & Solutions): Gaps between baseline and target states are analyzed. Here, ABBs are matched with concrete SBBs (commercial products, cloud services, or custom code) to implement the required functionality.
  4. Implementation & Deployment: SBBs are procured or developed, integrated via their published interfaces, and deployed according to architecture governance.
Throughout this evolution, maintaining published and reasonably stable interfaces is critical. It ensures that as blocks are replaced or upgraded, the broader architecture remains intact.
Architecture Patterns: The Blueprint for Using Blocks
pattern is an idea that has proven useful in one practical context and is likely to be useful in others. While building blocks are what you use, patterns tell you how, when, and why to use them.
Key Characteristics of Architecture Patterns:
  • Provide context for assembling building blocks.
  • Describe reusable solutions to recurring architectural problems.
  • Highlight trade-offs (e.g., performance vs. security, cost vs. flexibility).
  • Guide architects toward proven combinations of ABBs and SBBs that have succeeded in the past.
Patterns essentially serve as reference blueprints. Instead of reinventing the wheel for every project, architects can apply established patterns to accelerate design, reduce risk, and ensure consistency across the enterprise.
Beginner-Friendly Examples
Example 1: Customer Management Capability
  • ABB: Customer Data Management Service
    • Functionality: Store, retrieve, update, and secure customer records.
    • Interfaces: RESTful API for CRUD operations, OAuth 2.0 for authentication.
    • Rules: Must comply with data privacy regulations, support multi-tenant access.
  • SBB: Salesforce CRM OR Custom .NET Web App + SQL Server Database
    • Implementation: Real software purchased or built that fulfills the ABB’s specification.
    • Mapping: The CRM’s API matches the ABB’s interface requirements; configuration aligns with privacy rules.
Example 2: Enterprise Authentication
  • ABB: Identity & Access Management (IAM)
    • Functionality: Centralized login, multi-factor authentication, role-based access control, session management.
    • Interfaces: SAML/OIDC endpoints, LDAP directory sync.
  • SBB: Microsoft Entra ID (Azure AD) or Okta Identity Cloud
    • Implementation: Cloud-hosted SaaS products deployed to handle authentication across all enterprise applications.
Example 3: Payment Processing
  • ABB: Secure Payment Gateway
    • Functionality: Authorize, capture, and settle financial transactions; tokenize sensitive card data; generate audit logs.
    • Interfaces: PCI-DSS compliant API, webhook for transaction status.
  • SBB: Stripe API Integration or In-house Payment Module using AWS Payment Cryptography
    • Implementation: The chosen third-party service or internal development that realizes the payment ABB.
Key Takeaways
  • Building blocks are the foundational, reusable components of enterprise architecture.
  • A well-designed block has stable interfaces, is loosely coupled to implementation, and is both reusable and replaceable.
  • ABBs define what is needed (abstract, requirement-driven). SBBs define how it’s built (concrete, product-driven).
  • Building blocks evolve from abstract concepts in early ADM phases to specific implementations in later phases.
  • Architecture patterns provide proven blueprints for combining blocks, highlighting trade-offs and accelerating design.
  • Successful architectures only include necessary blocks, ensure standards compliance, and leverage published interfaces for seamless interoperability.
By mastering building blocks, architects can design flexible, cost-effective, and future-proof enterprise systems that align directly with business objectives while minimizing technical debt and vendor lock-in.
Reference
  1. TOGAF ADM Tools: Comprehensive overview of Visual Paradigm’s TOGAF Architecture Development Method (ADM) tools, featuring the ADM Process Navigator, guided step-by-step workflows, form-filling capabilities, deliverable composer, auto-versioning, shape/color legends, model extractor for element reuse, and architecture repository management. Supports all TOGAF ADM phases from Preliminary through Phase H with actionable instructions and sample deliverables.
  2. Step-by-Step Enterprise Architecture Tutorial with TOGAF ADM: Detailed hands-on tutorial demonstrating how to execute TOGAF ADM phases using Visual Paradigm. Walks through the Preliminary Phase with practical examples: scoping impacted organizations using ArchiMate diagrams, performing architecture maturity assessments with radar charts, completing activity steps, and generating/archiving TOGAF deliverables in the Architecture Repository.
  3. TOGAF ADM Software: Product page highlighting Visual Paradigm’s revolutionary TOGAF ADM software designed for EA teams. Features visual process maps for navigating ADM phases, integrated ArchiMate modeling, radar charts for maturity analysis, breakdown structures, scheduling tools, task management, form-based data entry, incremental artifact development, and one-click TOGAF deliverable generation with customizable report editor.
  4. TOGAF Software for Enterprise Architecture: In-depth guide explaining why TOGAF projects fail and how Visual Paradigm addresses common challenges. Compares traditional EA tools vs. Visual Paradigm’s Guide-Through and Just-in-Time process approaches. Details benefits: structured ADM phases with embedded instructions, progress indicators, incremental analysis/diagramming, automatic data transformation, task assignment, and seamless EA/PM/agile integration.
  5. TOGAF ADM Tool for Enterprise Architecture Tutorial: Step-by-step tutorial (published May 4, 2018; 78,537 views) demonstrating Visual Paradigm’s TOGAF ADM capabilities. Covers project setup, opening the ADM navigator, executing Preliminary Phase activities (scoping organizations, maturity assessment), using ArchiMate diagrams and forms, completing steps, generating deliverables, and managing the Architecture Repository. Includes sample data tables and diagram examples.
  6. Step-by-Step Enterprise Architecture Tutorial: TOGAF ADM phases, Visual Paradigm’s guided process, ArchiMate modeling, deliverable generation, and Architecture Repository usage.
  7. TOGAF ADM and Architecture Content Framework: Technical guide explaining the relationship between TOGAF ADM and the Architecture Content Framework. Defines key concepts: deliverables (contractually specified outputs), artifacts (catalogs/matrices/diagrams), and building blocks (reusable components). Details the content metamodel for describing architectural elements and their relationships. Emphasizes using the Content Framework as a companion to ADM for structured input/output management.
  8. Understanding the Difference Between TOGAF and ADM: Educational article (October 4, 2024) clarifying distinctions between TOGAF (the comprehensive framework) and ADM (the core methodology within TOGAF). Compares scope, functionality, components, phases, focus areas, governance coverage, use cases, flexibility, documentation requirements, and target audiences via detailed comparison table. Includes guidance on leveraging Visual Paradigm’s TOGAF ADM Guide-Through tool for implementation.
  9. The Evolution of TOGAF 10: Empowering Enterprise Architecture in the Age of Agility: Insightful article (August 1, 2024) on TOGAF 10’s enhancements for agile environments. Highlights modular structure for selective adoption, streamlined documentation, continuous evolution capabilities, and stronger IT-business alignment. Discusses how Visual Paradigm’s TOGAF Guide-Through tool bridges framework theory and practical implementation with guided workflows, collaborative modeling, automated documentation, and ADM integration.
