UML Class Diagram Tutorial
The UML Class diagram is a graphical notation used to construct and visualize object oriented systems. A class diagram in the Unified Modeling Language (UML) is a type of static structure diagram that describes the structure of a system by showing the system's:
  • classes,
  • their attributes,
  • operations (or methods),
  • and the relationships among objects.
Learn UML Faster, Better and Easier
Are you looking for a Free UML tool for learning UML faster, easier and quicker? Visual Paradigm Community Edition is a UML software that supports all UML diagram types. It is an international award-winning UML modeler, and yet it is easy-to-use, intuitive & completely free.
Free Download
What is a Class?
A Class is a blueprint for an object. Objects and classes go hand in hand. We can't talk about one without talking about the other. And the entire point of Object-Oriented Design is not about objects, it's about classes, because we use classes to create objects. So a class describes what an object will be, but it isn't the object itself.
In fact, classes describe the type of objects, while objects are usable instances of classes. Each Object was built from the same set of blueprints and therefore contains the same components (properties and methods). The standard meaning is that an object is an instance of a class and object - Objects have states and behaviors.
Example
A dog has states - color, name, breed as well as behaviors -wagging, barking, eating. An object is an instance of a class.
What is a class?
UML Class Notation
A class represent a concept which encapsulates state (attributes) and behavior (operations). Each attribute has a type. Each operation has a signature. The class name is the only mandatory information.
UML Class Notation
Class Name:
  • The name of the class appears in the first partition.
Class Attributes:
  • Attributes are shown in the second partition.
  • The attribute type is shown after the colon.
  • Attributes map onto member variables (data members) in code.
Class Operations (Methods):
  • Operations are shown in the third partition. They are services the class provides.
  • The return type of a method is shown after the colon at the end of the method signature.
  • The return type of method parameters are shown after the colon following the parameter name. Operations map onto class methods in code
Class Operations
Class Visibility
The +, - and # symbols before an attribute and operation name in a class denote the visibility of the attribute and operation.
Class Visibility
  • + denotes public attributes or operations
  • - denotes private attributes or operations
  • # denotes protected attributes or operations
Parameter Directionality
Each parameter in an operation (method) may be denoted as in, out or inout which specifies its direction with respect to the caller. This directionality is shown before the parameter name.
Perspectives of Class Diagram
The choice of perspective depends on how far along you are in the development process. During the formulation of a domain model, for example, you would seldom move past the conceptual perspective. Analysis models will typically feature a mix of conceptual and specification perspectives. Design model development will typically start with heavy emphasis on the specification perspective, and evolve into the implementation perspective.
A diagram can be interpreted from various perspectives:
  • Conceptual: represents the concepts in the domain
  • Specification: focus is on the interfaces of Abstract Data Type (ADTs) in the software
  • Implementation: describes how classes will implement their interfaces
The perspective affects the amount of detail to be supplied and the kinds of relationships worth presenting. As we mentioned above, the class name is the only mandatory information.
Relationships between classes
UML is not just about pretty pictures. If used correctly, UML precisely conveys how code should be implemented from diagrams. If precisely interpreted, the implemented code will correctly reflect the intent of the designer. Can you describe what each of the relationships mean relative to your target programming language shown in the Figure below?
If you can't yet recognize them, no problem this section is meant to help you to understand UML class relationships. A class may be involved in one or more relationships with other classes. A relationship can be one of the following types:
Inheritance (or Generalization):
A generalization is a taxonomic relationship between a more general classifier and a more specific classifier. Each instance of the specific classifier is also an indirect instance of the general classifier. Thus, the specific classifier inherits the features of the more general classifier.
  • Represents an "is-a" relationship.
  • An abstract class name is shown in italics.
  • SubClass1 and SubClass2 are specializations of SuperClass.
The figure below shows an example of inheritance hierarchy. SubClass1 and SubClass2 are derived from SuperClass. The relationship is displayed as a solid line with a hollow arrowhead that points from the child element to the parent element.
Inheritance Example - Shapes
The figure below shows an inheritance example with two styles. Although the connectors are drawn differently, they are semantically equivalent.
Association
Associations are relationships between classes in a UML Class Diagram. They are represented by a solid line between classes. Associations are typically named using a verb or verb phrase which reflects the real world problem domain.
Simple Association
  • A structural link between two peer classes.
  • There is an association between Class1 and Class2
The figure below shows an example of simple association. There is an association that connects the <<control>> class Class1 and <<boundary>> class Class2. The relationship is displayed as a solid line connecting the two classes.
Simple Association
Cardinality
Cardinality is expressed in terms of:
  • one to one
  • one to many
  • many to many
Cardinality
Aggregation
A special type of association.
  • It represents a "part of" relationship.
  • Class2 is part of Class1.
  • Many instances (denoted by the *) of Class2 can be associated with Class1.
  • Objects of Class1 and Class2 have separate lifetimes.
The figure below shows an example of aggregation. The relationship is displayed as a solid line with a unfilled diamond at the association end, which is connected to the class that represents the aggregate.
Aggregation
Composition
  • A special type of aggregation where parts are destroyed when the whole is destroyed.
  • Objects of Class2 live and die with Class1.
  • Class2 cannot stand by itself.
The figure below shows an example of composition. The relationship is displayed as a solid line with a filled diamond at the association end, which is connected to the class that represents the whole or composite.
Composition
Dependency
An object of one class might use an object of another class in the code of a method. If the object is not stored in any field, then this is modeled as a dependency relationship.
  • A special type of association.
  • Exists between two classes if changes to the definition of one may cause changes to the other (but not the other way around).
  • Class1 depends on Class2
The figure below shows an example of dependency. The relationship is displayed as a dashed line with an open arrow.
Dependency
The figure below shows another example of dependency. The Person class might have a hasRead method with a Book parameter that returns true if the person has read the book (perhaps by checking some database).
Dependency
Realization
Realization is a relationship between the blueprint class and the object containing its respective implementation level details. This object is said to realize the blueprint class. In other words, you can understand this as the relationship between the interface and the implementing class.
For example, the Owner interface might specify methods for acquiring property and disposing of property. The Person and Corporation classes need to implement these methods, possibly in very different ways.
Realization
Class Diagram Example: Order System
Class Diagram Example: GUI
A class diagram may also have notes attached to classes or relationships.
Try to Draw UML Class Diagram Now
You've learned what a Class Diagram is and how to draw a Class Diagram. It's time to draw a Class Diagram of your own. Get Visual Paradigm Community Edition, a free UML software, and create your own Class Diagram with the free Class Diagram tool. It's easy-to-use and intuitive.
Free Download
Master Class Diagrams Faster with AI Assistance
Learning notation and relationships is easier when you can see them in action. Use our AI-powered ecosystem to generate accurate Class Diagrams from descriptions, helping you validate your understanding of attributes, visibility, and associations.
Integrated AI Platforms
  • VP Desktop: Generate professional diagrams via AI and use full-featured editing tools for precision touch-ups.
  • AI Chatbot: Draft and refine Class Diagrams instantly through a conversational Chat Interface.
  • OpenDocs: Create dedicated Class Diagram pages or embed them into your technical project documents.
Specialized AI Apps
✨ AI Class Diagram Wizard: A dedicated step-by-step wizard to build classes with AI-suggested attributes and operations.
📋 Use Case Studio: Automatically identify domain classes and relationships directly from use case descriptions.
🏃 Agilien: Bridge Agile planning to design by generating Class Diagrams from Epics and User Stories.
🗄️ DB Modeler AI: Creates conceptual Class Diagrams as the foundation for database schema generation.
🏗️ MVC Architecture: Generates specialized Controller Class Diagrams to visualize system responsibilities.
Ready to put your tutorial knowledge into practice?
AI Class Diagram Guide View AI Ecosystem
